been mucking around underneath the car and noticed the rear subframe has a gap on the bottom, tried looking for some pics but nothing clear to confirm
is the gap normal and the rear subframe looks ok apart from surface rust?
been thinking of using some pineapples to further stiffen things up
https://www.sau.com.au/forums/topic/379453-rear-subframe-on-r32/
Pineapples sit in that gap. Most of us are just not used to seeing them without pineapples any more!
No they don't....
Have a better look at his photo. The subframe is sitting hard up against the rail. Indicates to me that the bushes are rooted and has allowed the weight of the car to sit onto the subframe instead of being supported by the bush.
The subframe bushes do two jobs, they locate the frame and also support the weight of the chassis.
There should be an even gap top and bottom when the factory bushes are in good condition.
Bad news for you is those bushes are an arse hole to replace. We did a set last week and it was not a fun job.
No they don't....
thanks for the diagnosis, that may explain why my passenger side rear wheel sits 5mm further out than the right side
if i were to buy bushes, whats a better type/option to purchase and is solid ones really that noisy?
also whats a reasonable amount to expect a workshop/suspension joint to do the work?
Skyline subframes are slightly offset from factory...for what reason I dont know...but they are
nooo, i have read few comments in regards to this, which shows up my rear wheel uneven-ess as its pretty flush to the guards, does the subframe allow for any adjustment?
Alloy rings just tend to make it really harsh. They do stiffen it up a lot, but it's rough and tough and takes all the give out of the mounts. I'm putting a different subframe into my car at some stage soon, and I'm using new Whiteline bushes to mount it.
in my scenario where the subframe is flat against the chassis on one of the sides, if i were to use the alloy rings despite the harshness, will it effectively correct the subframe positioning?
from what i have read, if u put say a whiteline bush kit in and then proceed to put the alloy rings on top, it renders the bushes useless, as effectively only the alloy rings are being utilised?
i would opt for the alloy rings however the proper bushes as an interim fix, and perhaps acquire a 2nd cradle to put bushes into in at my leisure
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
