i calculated how much its cost me so far..
f**kKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK
Just don't keep record. I know roughly how much I spent on my Pulsar in the time I had it. Lets just say when I stripped it for parts I made approx. 1/4 of it back and I sold the parts for $22K...
Haha nah just a pic from the web.. like KTMs but rare to get a supermoto one in Oz
I'd probably go a husky smr 511 because they're just under 500cc ($450 rego) and have about 50rwhp @ 118kg
Miss this old girl though:
SMR511:
Downside is 8.5l tank only sees around 150ks I guess my old DRZ400 did around 200-220
But wasn't really a issue because I don't use it on long trips, cept for when I run out after some mountain runs with Birds and he rides off :(
You're not gonna get a super sport over $156....?
Rimon, I do not share your taste in styling
well that, the initial price of a sportsbike, & the fact i want to go offroad + i reckon motards look cool :D
crazy mofo:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
