i cant remember that.
im pretty sure the mods started while on P's so there was no easy period.
although I dont know why I was scared, it was a wagon at the end of the day.
Edited by Sunkist
excellent, but the previous owner changed the mufflers so it has a terrible drone on the freeway (it's hard trying to source stock parts for an S2000). Probably the most fun I've had driving a car and certainly the most fun I've owned.
1) remove muffler
2) attach straightpipe
3) ????????
4) profit
That was the case with my Skyline, I have more boring plans for the S2000
not too tail happy in this weather? :P
Haven't had any trouble as of yet, it comes with 225s on the rear so they do okay in the wet. I've been very careful on corners and only hit vtec about 2-3 times because it hasn't stopped raining since I picked it up.
which is why I want to keep the exhaust stock :)
Future plans will be BBS LM, coilovers, front lip and spoiler. There isn't much point in performance mods with Hondas because you spend a lot of money and get little in return. Needs a new headunit too.
good ol' vtak :P
must be such a drain not being able to try stretch it's legs a bit after getting it due to the weather :/
although some rear squirmish action could always bring a smile to your face haha.
+1 induction noise though, prob sound cool on le honda
you have what i like to call, BBSitis, usually caused by hanging around roman for too long LOL
i came close to buying an s2000 too, i sort of regret it, and i sort of dont.
regret because they look so nice and go really well
dont regret because im not the smallest flamin mongrel, and id look hilarious in it.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
