  • Replies 91
Very enjoyable, ran anticlockwise figure 8 (as per Australian Championship held the other week), with so few entries, plenty of oportunity to work on improving times doing different things.
Only bummer, they closed up shop a bit early (around 4:30) and forgot a hat, so even with factor 30, got a bit of sun burn!
Awesome day. I ended up with a 67.1 but i had to leave early as hayfever knocked the stuffing outta me, just woke up after 16hrs of sleep :closedeyes:
Pity i probably missed anoher 2-3 runs. Would have been good to knock even more time off. Each run nearly killed about .8 of a second so definitely good room to improve. Running the track reverse Fig 8 was VERY interesting, quite different to the other way.
I hear Madden got a 66.x
Must have been the speed-hat LOL :merli:
great to met some more of the SAU crew, and overall a very enjoyable day. (apart from the sunburn)
look forward to seeing some of the incar vids when they get posted?
found a great vid that shows the reverse figure 8 layout
<iframe width="640" height="360" src="http://www.youtube.com/embed/l22zfLcm8-c?rel=0" frameborder="0" allowfullscreen></iframe>
RACE SOLUTIONS how much did they get paid to do what? good day beside nothing running on time, what is the point in having supp regs with a time line that was no where near it. All so where was the practice session not the stupid bloddy three lap sighting crock of shit. Also the last minute change of what track was going to be run.
Wasn't happy with the change of track layout, really wanted to see If I could improve on my times from earlier in the year.
Other than my car being slow, I enjoyed the day
I didn't read the Supp Regs haha, but ye would have preferred the "usual" way to gauge the mods I've done in the car in terms of time etc. The Reverse Fig 8 was still fun overall though.
Agree on the Race Solutions point. Two events I've been to recently where there has been a lot of time wasted on their behalf whilst they just sit in the 4WDs, especially when people come off. There is 1-2mins before anything happens... If i had some off and was in trouble, 1min is a long time. So certainly room for improvement there & hopefully someone is giving them feedback to improve what they are delivering.
Still had fun overall though which is what matters :thumbsup:
Wish i could've stayed till the end but if gates did indeed close early (Someone said they did?) then probably wouldn't have missed as much as i thought.
yes there are pics, Katie took a bunch on the day slowly uploading atm.
re times when WRX have their we will link ot it, however final times on the club championship won;t be done till after the preso night..(just to keep a few ppl in suspense..
M
and the rest of the pics:
https://picasaweb.google.com/100203254234701302909/HH_nov_11#
usual thing if you want high res :
get the file name from clicking photo info on the right
and get file name:
eg
Filename: IMG_3009.JPG
email me
mfsull at hotmail.com
and I'll send them over.
Sunburn was sure the word of the day.
The track layout is far more enjoyable than the normal layout. Though I can see that for gauging difference in skill and car from the previous event is a pita.
I've got some great video, the pictures Katie has taken are awesome.
Is that Her Majesty the Queen driving JP's Green S14 there?
:whistling: Yes I had a laugh when I saw that. Timing Katie. Least I didn't get called a queen!
How'd PI go Sunday, spotted the 1:51s, wouldn't have minded being there myself, instead of mowing the lawn at 5kph.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
