guys somebody has to know the r34 gtr headunit with all jap writing. i want to know what it all means. is the 2 3.5mm jacks aux inputs?
are you talking about the MFD fixed display or the TV unit that pops up from a GTT . they have translated it. search is your friend . lol
think brad - user ID ducati(something) has a translation for it in adelaide , chris rogers might as well ?
Confirmed, the one on the right is for input and supports video (NTSC). I managed to get my ipod touch going a while back.
Most of the other bottons are all for the Navi CD. If I have time on the weekend, I'll try to get photos etc but it took a stack of trial and error.
  • 2 years later...
Certainly have.
So you have the tv option in there OR the tv button that displays a message?
If its the latter then I can mod the unit so you can do video in.
That one is set up to do a reverse camera.
I have boards available that make this a plug in process for both the sharp and toshiba variants.
I took the sharp out of mine and installed a toshiba. If there's interest I will make that board available as well.
I have no idea which one mine is xD even though i'm eventually getting a double din headunit, this will be very useful for people who don't plan on getting double din headunit installed and want a reverse camera, i just want to see if i can do anything about plugging my Samsung Note 3 via AUX cable for now until i get my double din unit which is not anytime soon, any solutions?
Thanks
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
