Hey,
I have a two door r34 that I am parting out. Car is in immaculate condition with only 39,000 ks on the clock. Has factory bilstein suspension, sunroof and nismo 2.5 catback exhaust with the in car switch to control flow and loudness. Give me a call, pm or text (at a reasonably time of day ie before 10 pm at night!) for parts availability and prices.
My number is 0422641010.
Most parts in great nick. Rear wheel has been rashed and will need respray, but other 3 are in great nick. Tyres good all round. Also has factory floor mats in great condition.
Prefer pick up from Frankston area, Vic but will post registered if the price is right.
Edited by griffonfamily
  • Replies 91
As requested, here are the photos of items. Bilsteins dont seem to have any leaks but people are welcome to inspect. Only done 39,000 ks!!. Thanks
hi is the car complianced or is it a write off as might be interested in what you have left over after it has been wrecked , ie body
thanks
will still b e interested in 6 months if it takes that long
nick - 0404099310
Sold so far:
Head unit
Clutch fan
Centre console plastics
Auto gearknob
Auto shifter surround
Ashtray
Weathershields
Windscreen Washer bottle
Wheels and tyres
Spare wheel
Jack and tool kit
Steering wheel and airbag
interested in motor inc ecu loom sensors and turbo. plus delivery to wollongong nsw 2500 if possible.
Also interested in ECU only as well.
Sold so far:
Head unit
Clutch fan
Auto gearknob
Ashtray
Weathershields
Wheels and tyres
Spare wheel
Jack and tool kit
Front and rear seats
A pillar trims
Hey,
Hey you still got the mud guards ???
hey mate Im after a drivers seat belt, i need one for my 4 door but im going to find out of the 2 doors are the same. if they are the same how much for the seat belt freighted to adelaide suburb 5067
thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
