Hey guys just Want to sort this out before my engine goes in I read somewhere on here a while ago that when putting ball bearing turbos on a car ie 32GTR that you may need oil restrictors in the feed lines. I've done a heap of searches and can't manage to find it again so Im wonderin does this apply with my application or do Garrett restrict all their direct replacement turbos such as -5's?
Cheers in advance.
https://www.sau.com.au/forums/topic/380520-5-oil-feeds/
There's gotta be a reason why HKS supply banjo bolts with restrctors built in with their GTRS & GTSS turbo kits so one can only assume they are needed.
if you need the banjo bolts with the .8mm restrictor in them, you can get them on ebay from kando_dynamics.
https://www.sau.com.au/forums/topic/380520-5-oil-feeds/#findComment-6067161
Well the HKS GT-RS's that came off my car had NO restrictors in the core BUT had really stupidly small oil holes in the banjo bolt.
The off the shelf Garrett -5's that replaced them had the restrictors in the core hence no need for the HKS banjo's. Stock banjo's went back in.
https://www.sau.com.au/forums/topic/380520-5-oil-feeds/#findComment-6067775
Look into the oil feed and see if it is restricted.
My -1/-9 I installed last wk had the restrictor built in the core....To the bottom of the hole was completely sealed off, and to the side about where the thread stops there was a tiny hole probably 1mm or less. You actually have to look good to see it, and honestly I think the -5 would be the same.
Always wondered why HKS lncluded the banjos in the gtss kit....Probably just to justify the price : )
You'll also have a little work to do with the front turb oil drain pipe to get it to work.
BTW....No need to worry about the whole "S" thing....Just labelling AFAIK
https://www.sau.com.au/forums/topic/380520-5-oil-feeds/#findComment-6067971
Half the problem is knowing what to look for.. when you look into the oil feed on the turbo you don't easily see the 'restrictor' part. But actually you are looking right at it.
I took a photo of mine out of the turbo. You see the tiny hole on the side (this one is 0.8mm, the -5's came with 1.2mm originally)
hope these photos might help.. but to summarize, yes, -5 do come with a 1.2mm restrictor.
(oh and yes this turbo pictured is a -7.. but -5 is same)
Edited by R32 TT
https://www.sau.com.au/forums/topic/380520-5-oil-feeds/#findComment-6068069
Yeah Cheers man I've gotten to the point where everything measures up the same looks the same and to all accounts IS the same apart from the tags so they're going on lol!
Cheers R32 TT pic's will help out alot. I thought they would be restricted from factory just wanted to be sure.
Blue_vl_t yeah I'm running a trust aftermarket pump but I cant remember the exact thread I was reading and if it even refered to replacement bolt on kits might have just been aftermarket larger than stock items.
Anyway thanks all for the help.
https://www.sau.com.au/forums/topic/380520-5-oil-feeds/#findComment-6070908
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
