hi i have a s1 stagea and am looking at having to get a new radiator.
so i would like to know if they are the same as r33/34 gtt or gtr?
i could get a after market 1 but not want 1 at the moment as i have other things to do.
so i ask because my mate is changing his r34 gtr 1 and might be able to grab his stock 1 for the moment
https://www.sau.com.au/forums/topic/380570-radiator/
i think the r33gtr radiator did fit, there was a thread just before this somewhere asking the same question, try searching for it.
but in regards to the r34 radiator, i wouldnt know, i always thought they were thicker than the other skylines.
dont quote me on that tho.
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6068034
r33 gtst
you can also get them with the auto trans coolers still in them
about $200 from the ebay, mine is a koyorad branded one
http://www.ebay.com.au/itm/110712146710?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1998wt_1141
thats the one i got, but its for a manual
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6068256
ok i think its leaking at the top. i not shore but think its where the tank meets the core.
i am using my mates cap to see if it coming from there but i dont think it is
You can get the tank off and refitted. Cheaper than another rad
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6069571
i think i was looking at $170 for a new top tank + rod the core and clean it out
my top tank was split under the filler hole
or get a brand new rad for $200ish (i went the hard way and wasted $350ish on a justjap alloy rad, it was leaking after 18 months)
https://www.sau.com.au/forums/topic/380570-radiator/#findComment-6069694
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
