i have tested the vehicle on a gas bench and everything is good has a lambda reading of 1.02. and all the other gas levels are within specs. i have recently replaced the coils, spark plugs, fuel filter and o2 sensor . i have also cleaned the air fuelter and afm.
the vehicle runs fine at idle but once you start crusing along anywhere between 80 and 120 with the engine at operating temperature the car se
ems to jolt as if a really bad miss is present.
i have also noticed that the power light flashes on start up. after running diagnostis the lock up solenoid signal is missing or faulty or something cant remember exactly what it means. could this have something to do with it?
the car is a 1993 nissan skyline r33 gts with an auto transmission.
any idea would be appreciated
https://www.sau.com.au/forums/topic/380791-r33-missfire-on-cruise/
This is why I ask is it actually the engine missing or the transmission slipping/dropping out
Do the revs drop when this happens or do they stay the same/rise?
is it while cruising or while comming off the throttle? cause mine has started doing that
When you come off throttle and in gear the car should just hummm to a lower speed then it will burble when the rpm is too low for the gear. My car was running perfectly during cruise, now it lean pops its arse off ONLY during cruising. Full throttle, medium throttle etc is fine. Touching the throttle lightly to maintain a steady cruise speed sees lean popping.
500rpm drop is fair big... If it was your gearbox it would go up rather than down... Lean popping will cause your engines rpm to splutter around. If you have a big exhaust, hold the rpm with the window shut and you should hear the thud of the lean pop. My car is like. pop..........pop.....pop pop pop etc and revs bounce around and the car will jitter. Misfire sounds like a machine gun, kind of like lean pop but VERY rapid.
Only way is by sound and by AFR plots. This is misfire
its not a straight 500 drop. alot of the time i get multiples in a row adding up to 500 rpm. ill try your check next time it starts happening. what is your sugested fix for a lean pop?
I fixed my lean pop today, required a touch up in some cells in the tune. If you are running after market ECU, injectors and what not then it is very likely you will suffer from lean pop. Its common on Skylines and they require a little more fuel then stoich to run smooth.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
