  • Replies 203
:banana:
Shake Shake Shake
So anyhoo Ive had the t78 on ebay for a few days now...just to see if there is any intrest..and because it looks look bloody hard to get it all to fit in nicely...and yep...reserve has been met :D
Sooooo on the hunt for something that is maybe a bit more responsive on the 1jz....thinking maybe a PT6262...but dunno yet...will see what happens I guess
lol...well 2 hours later the turbo oil drain is fitted....sounds like a simple job yes......LOL
1JZ Soarer = same a TT 300ZX lol
had to take out a steering rack mount bolt, turn it upside down, so the bolt head faces the sky and make up a washer for it.
Looks like the oil drain kit I bought is for a front or rear sump JZ and not the mid sump engine....oh well...its in now...goes around infront of the bottom radiator hose to make sure it clears the manifold (plus its a bit long)
Also discovered the front crank seal is leaking a bit (common JZ problem) so I am covered in oil after being under the car.
Now just have to elongate the holes in the manifold flange (lol flange) which will be fun using my pissy little dremel on stainless....mind you I have ported cast iron heads using it lol
The 6262 exhaust wheel will choke before you can benefit from the high flow front wheel.. I doubt you'll be able to run 30+psi on a gt35 sized exhaust wheel.. Id go straight to the 65 rear wheel and deal with a few hundred extra lag.. What gearbox you running?
Standard Auto Trans for now.
I wasnt really concerned abooooot the 62mm rear wheel, I am more worried about the small split housing.
But how much more lag will the 6266 have? At this stage it looks like the 6262 will only be 500rpm in front of the t78
Will only be turning to 7200rpm until I can build an engine....then It will go OVER 9000! (well more like 8000 lol)
Hmm more research needed
As Lith mentioned in the precision thread plain bearings aren't known for reliability if I was going to run low boost I'd just go with something tested like a 3582.. If you have plans of building the motor I'd scarifices a small amount of lag increase and get the 65 rear then you have the option of turning it up later. If you go 6262 your limiting yourself for a few hundred rpm spool..
yeah, just found a few results of 6265s making 400+kws and reasonable response, so might be the go
MV kit I will probably get...but I am hankering for a manual box, so time will tell what i'm going to do there.
I do like corners more than drag strips these days lol.
I think I have decided on a PT6262 though, and will just wind boost into it until it stops making power...the auto will go pop before the turbo gets into its stride anyway. and 6262s have run 8s in EVO's so we shall see
+ I still have standard cams and head so a 6266 will be wasted on this engine.
will go something silly big if I build a 2J ;)
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
