the tower falling in caspian is cool - happens when 1 team has 20 tickets left
agree
i was running along the field toward antenna when it started falling.
behind the keyboard yelled HOLY F*** and got my character to run in the opposite direction with it just missing my player.
heart was genuinely racing
SO COOL!
Lol I've done the same. Trying to go third person view in a tank and it just wouldn't happen, until I realized its a hardcore server…
Is there anything different regarding bullet damage in hardcore? It's difficult to determine without the health bar.
These are the requirements for the 10 different assignments that each unlock a new weapon in the upcoming Back to Karkand expansion for Battlefield 3:
FAMAS – “Best Friend Forever”
10 Revives
10 Heals
HK53 – “Fixing it”
10 Repairs
1 Kill with the repair tool
QBB-95 – “Let it rain”
20 Kills with Light Machine Guns
2 Mortar kills
QBU-88 – “Specops”
20 Kills with sniper
6 Laser designations
PP-19 – “Familiar Territory”
ARM 10 MCOM stations
10 Flag captures
2 Hours played on Strike at Karkand
L85A2 – “Professional Russian”
100 Assault rifle kills
20 Grenade launcher kills
Win 5 Squad Deathmatch rounds
QBZ-95B – “It goes Boom!”
50 Kills with AT rocket
1 Enemy vehicle destroyed using the repair tool
Win 5 Conquest rounds
MG36 – “Keep your head down”
100 Kills with Light MG
50 Suppression Assists
50 Ammo Resupply Assists
L96 – “Creeping Death”
50 Headshots
50 Spot Assists
5 Knife kills
MK3A1 – “Scarred Veteran”
10 Kills with the PP-19
6 Kills with the DPV Jeep
10 Kills with the BTR-90 APC
2 Hours played on Sharqi Peninsula
2 Hours played on Gulf of Oman
HardCore = No Hud, 3rd person view or 3D spotting, health is set at 60%
Keen to join a clan for BF3 competition ladder matches?
Swing by sinners.net.au & post your application in the recruitment thread.
Friendly bunch of social gamers.
No you want death inc www.deathinc.com.au :P
no neither of those :P you want Cock n Bull gaming cnbgaming.net.au
or sob tea tog yadda yadda
should make a thread where we all nominate a clan and prospective people can check them all out
Ill see you in the SIN v TEA match :P... That is if its on a good day.
Edited by Cozi
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
