the tower falling in caspian is cool - happens when 1 team has 20 tickets left
agree
i was running along the field toward antenna when it started falling.
behind the keyboard yelled HOLY F*** and got my character to run in the opposite direction with it just missing my player.
heart was genuinely racing
SO COOL!
Lol I've done the same. Trying to go third person view in a tank and it just wouldn't happen, until I realized its a hardcore server…
Is there anything different regarding bullet damage in hardcore? It's difficult to determine without the health bar.
These are the requirements for the 10 different assignments that each unlock a new weapon in the upcoming Back to Karkand expansion for Battlefield 3:
FAMAS – “Best Friend Forever”
10 Revives
10 Heals
HK53 – “Fixing it”
10 Repairs
1 Kill with the repair tool
QBB-95 – “Let it rain”
20 Kills with Light Machine Guns
2 Mortar kills
QBU-88 – “Specops”
20 Kills with sniper
6 Laser designations
PP-19 – “Familiar Territory”
ARM 10 MCOM stations
10 Flag captures
2 Hours played on Strike at Karkand
L85A2 – “Professional Russian”
100 Assault rifle kills
20 Grenade launcher kills
Win 5 Squad Deathmatch rounds
QBZ-95B – “It goes Boom!”
50 Kills with AT rocket
1 Enemy vehicle destroyed using the repair tool
Win 5 Conquest rounds
MG36 – “Keep your head down”
100 Kills with Light MG
50 Suppression Assists
50 Ammo Resupply Assists
L96 – “Creeping Death”
50 Headshots
50 Spot Assists
5 Knife kills
MK3A1 – “Scarred Veteran”
10 Kills with the PP-19
6 Kills with the DPV Jeep
10 Kills with the BTR-90 APC
2 Hours played on Sharqi Peninsula
2 Hours played on Gulf of Oman
HardCore = No Hud, 3rd person view or 3D spotting, health is set at 60%
Keen to join a clan for BF3 competition ladder matches?
Swing by sinners.net.au & post your application in the recruitment thread.
Friendly bunch of social gamers.
No you want death inc www.deathinc.com.au :P
no neither of those :P you want Cock n Bull gaming cnbgaming.net.au
or sob tea tog yadda yadda
should make a thread where we all nominate a clan and prospective people can check them all out
Ill see you in the SIN v TEA match :P... That is if its on a good day.
Edited by Cozi
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
