  • Replies 886
Ok I'm sick of reading different opinions. What is the consensus on running in a rebuilt motor. I would like a step by step from the moment I pour water and oil into it if possible. I don't want there to be any chance of me stuffing it up.
Thanks in advance.
I recommend you get someone to do all the work for you with warranty, otherwise I reckon we'll be soon reading another thread titled 'fresh engine installed, but still having problems'
ok so here is some more info, one of my valves in cylinder 5 was about to drop in, and my head has marks from where the head gasket was soon to blow. so looks like i pulled it down just in time. on another bad note, when i had my front guard replaced a few years ago they dodged it up and used a holden indicator bulb holder and just electrical taped it on to hold it together so now my clear indicator housing wont work :@ another call to just cars to get more repairs done, glad they have life time guarantee on repairs. this is the 4th time it has had to get repairs done.
and a strange question. i need to provide my stem seals and cam seals for the head to be re assembled, in my gasket kit there is a packet with 12 stem seals, a packet with 12 stem seals and 1 big seal (looks like a cam seal to me) is there only supposed to be 1 cam seal? the only other seals in the kit is a packet with 2 seals the same as the cam seal and a rear? oil/main? seal. could one of these be the other cam seal?
Why would you strip an engine down for a rebuild and use 2nd hand parts if unsure of the condition?
If you can replace it and your not sure of the life condition...replace it while you can.
Last thing you want is a fresh built engine, 2nd hand oil pump, final tune, youll head out and give it a boot full and
hit limiter a few times and then the collar or something fouls
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
