Ok, I thought it would be a good idea but just confirming things. This is my first Nissan rebuild so parts that are actually easy to buy is new to me.
I can only find 3 pumps, n1, tomei and nitto. I'm pretty sure that the tomei and nitto would be over kill, but what about the n1. Is it too big too?
  • Replies 886
For future reference. The valves listed in the ferea catalogue are different to the Nissan valves. My machinist ordered one in to replace my worn out one and it didnt have the step down for the retainers, $45 was what he paid for it. Nissan are supplying me with a genuine one for $34.
The machinist was going to replace one valve yes. I didnt realize it was a different sort of valve, I never saw it. The ferea was the only one he could find for the 25neo.
Yep. Also know the feeling of trying to work out a problem that seems so simple to others, and yet in the end has nothing to do with what anyone said. Chocco, not everyone here is an expert on cars, give the guy a break.
Lilcrash, sorry if I missed it mate, but have you explained how you have your breathers plumbed in? I'm assuming you're using a catch can and it's not just the stock setup yeh?
Like when my car wouldn't start, I tried everything then suggested broken camshaft, everyone lold and said no way, in the end it was an broken camshaft haha.
Just read all this thread, when you finally get it running again promise you won't run more than 10psi without getting it to a tuner first, get the tuner to strip out timing and make it ridiculously rich, even up in the load cells you aren't close to touching. Then go play with the actuators and get the right boost, once you have the right boost take it back and get it tuned at that boost.
Remember if you change nothing you will blow the new motor up just as fast, the issue wasn't with the motor, it was with everything else.
Should save a repeat incident. Good luck with it all. :)
Edited by Rolls
I'm still confused as to what went wrong but yeah I am putting the smallest actuator I have here on I think it's about 7psi, depending on if I run it in on the road or on the dyno it will go straight to the dyno for run in or straight to the dyno after run in. I will get it looked over, dyno checked at 7psi and once I'm sure nothing is faulty I will put the original 20psi actuator ( that dropped to 14psi ) on and see what happens. hopefully It will hold 18psi to redline. If not il just put the 7psi on and turn it up to 1 bar and leave it.
Just for future reference, problems I've found so far - head gasket pealing apart, loose exhaust manifold nut( cause for the noise? ), inlet valve number 9 was about to drop as the retainer/valve stem area was worn and worn out rings in cyl 1
You ran 25psi without a tune, that is what went wrong. Even 20psi when tuned for 15psi will almost certainly detonate. I remember telling you in the hypergear thread months ago not to do this, all it takes is 10 seconds of sustained detonation and pop goes your motor is the result the majority of the time.
Don't do anything and see what happens, get it on a dyno first thing and do not boost it even once. Get the tune right, then play with things WHILST on the dyno. If you don't I can guarantee you will blow up your new motor.
Please DO NOT put the 20psi actuator on without being on the dyno. All your problems that you listed are caused by detonation.
Edited by Rolls
yeah i meant i would be doing all the stuffing around while on the dyno. if its all caused by detonation then there is my answer, i didnt realize detonation could wear out rings. but it is good to know that the tune is to blame. so thanx *** *********** for all the problems you have caused, apart from the oil pouring out which was caused by the rings dieing due to prolonged detonation im guessing. that same detonation sound could be heard from the second i picked up my car, thats half the reason i called them 10 minutes after i picked it up, and never got a call back.
oh well new motor and new tuner, lets hope it all goes well.
I was on here asking questions about it when all hell broke lose in the first place.
I was never intending to make that much boost, I didn't really think the new actuator was that much bigger then my old one. Neither of the other actuators make the boost they are specified as so yeah stao said 22/23. I thought oh yeah 18/19.
Edited by lilcrash
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
