The only thing I'm scared of is the clutch plate coming loose, 3 of the bolts stretched so I replaced them but I'm worried the rest might let go.
I'm trying to find a picture of how the wiring gets tidied up, I took photos on my phone when i pulled it out but it crashed and I lost them all.
Edited by lilcrash
  • Replies 886
Have been reading along since you started, just unable to comment as I haven't got a clue.
Gotta say man, hats off to your persistence. I can imagine how nerve wrecking it would be to be doing the assembly of your engine for the first time, so the fact that you've pressed on with it and not payed someone else to do it despite not getting any help from anyone here is quite impressive. I do hope it all goes well for you, hopefully those dog hairs don't cause any trouble laugh.gif
Ok this is all I have left to do/buy.
Engine mount nuts for the bottom side (don't know where they ended up), set of belts, 3 bolts in passenger side drive shaft, dump pipe bolts/studs, fuel filter, fit turbo oil drain, buy some hose for the cam breathers.
So yeah should be doing my mountain run on Friday night.
Brain fart again. My car has an imobiliser. F**k im stupid. Just warmed her up and went for a 100km drive though the country side. Got home and turned her off, realized I wasn't in the garage and it wouldn't start :/. Error 21 ignition signal fault, car started 10 times with this fault.
i just did what i read on the net, warmed it up with a high idle, checked for leaks (does have an exhaust leak at the cat to fix but i can do that anytime), then headed for the biggest hills around and loaded it up and down them until i had done 100km (wife needed to wee anyway) and headed for home)
im organizing with my tuner now to get it done asap, ive got my parents car to drive anyway so it can just sit and wait until a few more km are put through it.
my wife was watching the data logging while we were driving and nothing looked dangerous. it made 1-2psi once or twice up hills. although it feels like my hand brake is on, timing out maybe, the cas is lined up with the old marks so it cant be far off, if at all.
other then that, no weird noises or rough running
When I saw the guys do the timing on my car at the shop, they removed the coil pack from cylinder 1, put some sort of a plug from the coil pack to the spark plug then clamped the timing light to that line going to the spark plug. Has to be cylinder one, any induction light will pick up the signal through the wire to the spark and flash when it does.
Bond - yeah I thought that.
Sarge - I wanted to avoid pulling that apart before I changed the plugs for the tune.
I should hear back from my tuner tonight so il see what e wants to do.
Ok just did an oil change. 115km worth of driving
There is about 15-20 big pieces of something. And the oil has a generally glittery look. Millions of tiny particles. I've kept an oil sample.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
