  • Replies 886
Ok. Timing. Orange is 0 degrees? Then every mark is 5 degrees? I used the loop at the back of the coil pack loom.
My timing was sitting on the 5th mark so 25*btdc? I have adjusted it as far around as I could get it and it starts at 10dgrees and slowly works its way around to about 16/17dgrees. Is this ok?
Should be around the 15deg I think
If it were me I would want It bang on that I dunno if tha 2deg adv will cause detination
But if u had it set a 25 deg bftdc that defiantly would not of helped anything and would have no doubt been detonating or not far of it :-/
Also most of the RBs I have owned have usually have there cas set in the middle .
Only once have I had one set on max retard and that was when my cas was on its way out and started advancing the timing randomly hahhaha
Good luck buddy
Yeah. I'm gonna make up a test lead and try it again. It doesn't seam right at all. It's running really well at the half way point where the old mark is. I just wanted to check
ok its back at about half way, on the 3rd line on the harmonic balancer.
did a compression test, 191 170 170 170 170 170 , but bear in mind that i had spilled oil and the 1st cyl copped a lil bit of oil that i couldnt get out with my rag, il retest in a week or so after ive done the 1000km.
but ive noticed that my pcv seal is broken in half. so i need to find another one of those.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
