  • Replies 886
Ok. Timing. Orange is 0 degrees? Then every mark is 5 degrees? I used the loop at the back of the coil pack loom.
My timing was sitting on the 5th mark so 25*btdc? I have adjusted it as far around as I could get it and it starts at 10dgrees and slowly works its way around to about 16/17dgrees. Is this ok?
Should be around the 15deg I think
If it were me I would want It bang on that I dunno if tha 2deg adv will cause detination
But if u had it set a 25 deg bftdc that defiantly would not of helped anything and would have no doubt been detonating or not far of it :-/
Also most of the RBs I have owned have usually have there cas set in the middle .
Only once have I had one set on max retard and that was when my cas was on its way out and started advancing the timing randomly hahhaha
Good luck buddy
Yeah. I'm gonna make up a test lead and try it again. It doesn't seam right at all. It's running really well at the half way point where the old mark is. I just wanted to check
ok its back at about half way, on the 3rd line on the harmonic balancer.
did a compression test, 191 170 170 170 170 170 , but bear in mind that i had spilled oil and the 1st cyl copped a lil bit of oil that i couldnt get out with my rag, il retest in a week or so after ive done the 1000km.
but ive noticed that my pcv seal is broken in half. so i need to find another one of those.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
