Tangles Posted March 17, 2012 Share Posted March 17, 2012 At least now you know its nothing f*Ing up. Fit the gasket and get it tuned, even if its a low boost quick tune somewhere prior to getting it in to your trusted tuner. Bloody important mate, don't just 'wait', get a basic tune done, otherwise you run the risk of ..... Well, you know. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278369 Share on other sites More sharing options...
lilcrash Posted March 17, 2012 Author Share Posted March 17, 2012 I've still got over 300km until I even think about tuning. But at the moment it looks like I'm driving it over 800kms down to dvs to tune it. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278436 Share on other sites More sharing options...
zebra Posted March 17, 2012 Share Posted March 17, 2012 whut? 300kms? for what? Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278439 Share on other sites More sharing options...
Tangles Posted March 17, 2012 Share Posted March 17, 2012 Well then stop boosting it past a couple of psi (in my opinion undo the wastegate spring again). Sure, load up the engine but without boost. Detonation is Not your friend. Hitting 16psi isn't the right way about it. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278448 Share on other sites More sharing options...
DVS JEZ Posted March 17, 2012 Share Posted March 17, 2012 When u pull ur motor out send me ur ecu and i will adjust the timing map. Or Keep boost setting to a minimum, and adjust the base timing back 5 degree's Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278510 Share on other sites More sharing options...
lilcrash Posted March 17, 2012 Author Share Posted March 17, 2012 300 km until I switch to normal oil. End of run in period. I haven't let it get over 3/4psi again. I've been very very careful. I won't have it off the road long enough to send my ecu to you. And I can't adjust anything without a password can I? Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278581 Share on other sites More sharing options...
DVS JEZ Posted March 17, 2012 Share Posted March 17, 2012 There shouldnt be a password but u will need the diftware and a license. Just be careful with ur driving. Are u following any run in procedures? Did u get an oil analysis done ? Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278690 Share on other sites More sharing options...
lilcrash Posted March 17, 2012 Author Share Posted March 17, 2012 Yeah. That's what I meant. I think I might just have to put my car into a mechanic to get the oil pump gasket replaced. It's just too big of a job to do it again. Yeah I just did what a majority of people have done. High load slowly increasing max rpm. Oil change at 100km and 1000km. The oil analysis came back fine. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278713 Share on other sites More sharing options...
lilcrash Posted March 18, 2012 Author Share Posted March 18, 2012 Ok gasket installed . Now just to hope it holds up ok. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6278913 Share on other sites More sharing options...
Bond Posted March 18, 2012 Share Posted March 18, 2012 How did you do it so quick? Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279024 Share on other sites More sharing options...
BOOZTJUNKEY Posted March 18, 2012 Share Posted March 18, 2012 ^^^^ this I thought u were getting a mechanic to overcharge u ? Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279031 Share on other sites More sharing options...
Tangles Posted March 18, 2012 Share Posted March 18, 2012 wow; well done!! query - how many kms have you done so far on the running-in? Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279050 Share on other sites More sharing options...
Rolls Posted March 18, 2012 Share Posted March 18, 2012 It only takes a couple hours to pull the timing cover and all the ancillary belts etc off to get to the oil pump. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279092 Share on other sites More sharing options...
lilcrash Posted March 18, 2012 Author Share Posted March 18, 2012 it wasnt as hard as i thought it would be. i knew where all the bolts were this time so that kind of helped. almost 700km so far. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279118 Share on other sites More sharing options...
DVS JEZ Posted March 18, 2012 Share Posted March 18, 2012 But u have to remove sump to remove oil pump? Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279475 Share on other sites More sharing options...
zebra Posted March 18, 2012 Share Posted March 18, 2012 you can wriggle it (the pump) enough to just clear the dowels, not the way I would do it though Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279510 Share on other sites More sharing options...
The Mafia Posted March 18, 2012 Share Posted March 18, 2012 But then you risk a leak between the oil pump and the sump? I end up puckering my as$hole when reading a fair bit of stuff in this thread. Lol. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279528 Share on other sites More sharing options...
Rolls Posted March 18, 2012 Share Posted March 18, 2012 you can wriggle it (the pump) enough to just clear the dowels, not the way I would do it though This is what I've heard you can do as well, be pretty easy to f**k it up though. Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279546 Share on other sites More sharing options...
zebra Posted March 18, 2012 Share Posted March 18, 2012 Ye as Mafia said, re-sealing under the pump to the sump would be tricky at best Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279681 Share on other sites More sharing options...
lilcrash Posted March 18, 2012 Author Share Posted March 18, 2012 (edited) We dropped the sump just enough to clear the pump, cleaned it up and re sealed it all. But it all went pear shaped this morning. I went to change the oil pressure sender over and it fell apart. So a mad push bike ride to the train station and now in on the train on my way to being late for work. Edited March 18, 2012 by lilcrash Link to comment https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/page/32/#findComment-6279822 Share on other sites More sharing options...
