Import Monster Sauvic Deca Motorkhana - 2011 Round 4
someone sent a fax on thursday @ 5:55pm, this came through blank... no numbers on the top... please resend
that may of been me :whistling:
first time at using the new fax machine lol. have u got a entry for brad humphrys.?
  • Replies 154
Posted Images
Will do entry tomorrow been 3 + years since a 31 has hit DECA with me.
Good to see.
so who reckons a rwd will win this deca? :whistling:
I do :)
A rwd may very well win this deca BUT the question is which rwds will come close and complain about not winning? Theres a few on the list...
Will be a fun one :)
i hope so too lol.
i was already goin to winton to pit crew on the sun so i thought i may aswell enter deca and make it a wk end of it.
Stay saturday night... you'll love it.
It's the other half for deca.... :cheers:
I'm not sure if this is meant to be some big secret or anything....anyway
Anyone who has been to DECA before, this DECA has a little twist in it, well several new little twists....
We are going to need a couple more helpers on the day to run this section of the day, wayno will have a thread up soon. So bring ya mate or gf/bf along to help out.
They could win $50 worth of fuel, just for helping out.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
