hi all,
recently bought the car. it has a drift iridium (digital) boost gauge. ad idle its reading -18psi. is that a normal/correct reading, or is the gauge malfunctioning. for some reason i think it should be reading less.
the car is pretty much bone stock mechanically save for a CAI, exhaust, intercooler, boost controller (running stock boost level).
forgive me for my ignorance, its my first r33.
thanks
https://www.sau.com.au/forums/topic/381472-r33-gts-t-vacuum-at-idle/
Yep Psi is a measure of positive pressure
And negative pressure. Pressure units are quite universal. It's just that manifold vacuum is traditionally read in some of the more bullshit units like inches or mm of mercury. It shits me to tears that whilst we have a perfectly good set of self consistent SI units for pressure (Pa, dPa, hPa, kPa, MPa) that people continue to talk in rubbishy units based on the column height of some randomly selected fluid like mercury or water. It's time to come kicking and screaming into the 20th century is what I say.
Isnt it because Mercury isnt affected by air density as much?
Therefore measuring head flow in mmHg or inHg is more consistant, rather than saying x port flows y cfm at 22.14646363 deg C and 1009 QNH.
I think...lol
I've seen mercury and water used, there is a reason i just dontt remember
A negative psi value does really exist. you can't have below 0psi in a vessel. 0 pounds/square inch
Remembering that 0psi on your boost gauge is still 1atmosphere
Yeah you can. Absolutely no reason why you cannot express it in psi. The positive pressure is outside the vessel.
psi is a measure of force (pounds force) per unit area (square inch). So is any SI unit. The Pascal (Pa) is defined to be one Newton (force) per square metre.
same same. Just that SI units don't suck because they are easily convertible from one to another without having to use/remember arbitrary conversion factors. And the mmHg and mmH2O units require that you use the force of gravity to convert them (9.807 m/s2) which is gay, and is not universal because the same real pressure would give you a different fluid column height on a different planet (or even a different height on different parts of Earth where the force of gravity is slightly different from elsewhere. It is a very small difference though!)
cheers
Makes no difference whether you're talking absolute or gauge pressure. It's all pressure. If you totally evacuate a volume you have zero absolute pressure in it. That's zero psi, zero kPa, etc etc. The gauge pressure (relative to 1 atm pressure outside the vessel) inside is -1 atm, -14.7 psi, -101.325kPa (assuming we're at sea level of course). Let a little bit of air in there, and you might have a pressure of 1 psi absolute, -13.7 psi gauge.
cheers
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
