Hi all, looking for some guidance on what to do with my car.
95 r33 gtst, blew built engine recently, put in a second hand motor, drove for 1 day, thermostat stopped working, overheated and blew head gasket likely.
Telltale symptoms are white smoke on idle and water/coolant spitting out from the exhaust for the blown HG. Car also idles upto 80+degrees and the top hose gets hot but the bottom hose stays cold (so stuck thermostat i guess). Radiator is an alloy unit and almost positive not blocked.
Am quite poor nowaways due to family and commitments and just spent a lot dropping the second hand motor in.
Where should i go from here? Either sell it/wreck it or do another f*cking motor and get it back on the road again.
I'm fairly confident with doing my own work but have never opened an engine before (but am keen). I have limited garage space but do have a decent collection of tools etc.
I also still have the dead built motor at the mechanics and the BHG motor is of course still in car and running.
What's my best option in your opinion? Pull head off and replace headgasket on standard motor? Do i need to get the head machined for this seeing as it is probably warped from the overheating and BHG or is the head likely no good to reuse because it's warped?
Head on the built motor isn't warped but may have a dead valve or two from when a piston failed so that's always an option (get it refreshed and reuse maybe).
Tried to keep post as short as possible sorry. And i would REALLY appreciate any and all help. I've drained myself $$ keeping this car and it's one of only few things that keeps me sane/happy and feel ultra passionate about.
I'll have a fair few questions to follow likely once i get some guidance on what to do, all to do with doing the work myself or whether something is suitable i guess (for example is a warped head reusable ).
https://www.sau.com.au/forums/topic/382092-guidance-on-dying-33-please/
Hi i would remove the head which you will need a 10mm male hex socket
take to machine shop and have it skimmed and checked for cracks buy new
std gasket and put it back together with a new thermostat and make sur that
the cooling system is working before you test drive it and you should be fine.
its your cheapest altenitive...
I learnt the same lesson many years ago in a 62 mini, the thermostat never opened after an engine rebuild and it had no temp gauge. >_<
Now I always test them in hot water first. lol.
Looks like youre ripping the head off Jon.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
