May not be relevant but cam gears made a hell of a difference on my 25.
2835pro s all in (18psi) by 3200rpm, but I have a ff plenum etc and with the new huffer have inherited a bit of compressor surge which Jez will be working on for me in a couple of weeks.
Ok so went on the dyno last night made 242kw with major wheel spin from 5 grand on so can't get a proper reading had a extra 100kg in the boot and still spinning. There is a restriction somewhere holding it back as well will be playing today im thinking wastegate pipe so is jez so more fab needed will be opening it up to 40mm id pipe and further down the exhaust. Setup is stock rb20 with td06h running 18 pound and your usual breathing mods seeing full boost (on the road) 1st 4800 2nd 4700 3rd 4500 4th 4300 there abouts anyway didn't bother with 5th that's with mbc removed running gate pressure 10 pound spring. Now going to get a ebc and hope it rids my lag issues with a contoller. Any suggestions on why a mbc would be causing lag and please no dick answers.
Yeah wanted to find the issue and that was it. When it was connected wasn't seeing any boost untill 5800 so I though something is seriously wrong was worried I broke something. Also forgot to mention I lost around 30kw by plumbing in the external gate. As we did a power run before touching anything is that normal?
This is the least of my worries just pulled the intake manifold off for suspected blown gasket only to find a half empty radiator and milky brown water next up is comp test and a punch in the face by myself soon. My day just got shit I think
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
