Say what?
Fiberglass replacement part/panel is what FRP stands for
lol ---> FRP meaning! :)
Most kit cars & some manufacturers cars are made from frp or carbon, kevlar and a few other alternate materials. So im sure it would be possible to get them engineered if need be.
I had frp panels all over one of my cars for several years, bonnet, boot, 1/4s, aprons etc, never had a problem with it. Probably no-one ever noticed, being painted?!
The supplier of Fibreglass bonnets with ADR approval is Blits Bodykits in QLD. I am unsure if there approval carries over to other states or not as I am unsure on how the whole process works.
The website is http://www.blitsbodykits.com.au/
problem is when you change from steel to FRP or even aluminium (GTR guards etc) it changes the "crash worthyness" of the car, hence making it un-roadworthy.
It sucks because front guards are not structural, but in the even of a prang fibreglass/carbon splinters will spray everywhere, even more so if you hit a pedestrian.
If you have the budget to crash test all your panels (like blits did) i.e crash your car into a wall a few times then you can produce adr approved stuff.
I'd be dubious if an engineer will touch stuff like that, but it may be possible given enough cash.
In saying that I had a Carbon bonnet on the R33 for years an never got picked up on it.
completely different rules apply for kit cars to mass production cars. same with hot rods when run on limited rego
Say what?
And no not legal in either state
wikipedia says FRP stands for fibreglass reinforced plastic . . . BUT in this context means something else
BRISBANE , i thought so = NO RULES
Just a quick quote from the blits website.
"BLITS is the first Australian company in Australia to manufacture street legal fibreglass bonnets, that made for federal regulation transport approval Australia wide".
So it would appear they are approved for use in all states and not just QLD.
called RTA no problem with fiberglass guards .... then called an engeineer here no problem went over the pits with mine 30mm fiberglass front and rear guards passed no worries words stated to me by the inspector " i have no problem with these as they dont fall under any ADR restrictions" ? he also had no problem with my bonnet pins?
anyway not sure in melbourne but call and ask if you can or not?
2.7.1 Strength and Thickness
The thickness, of non-intrusion panels, with gel coat removed, must be at least 3.5mm.
Bonnets and guards are examples of non-intrusion panels
The strength and thickness of structural components such as floorpans and bodies that
incorporate seatbelt anchorages, door hinges and latches etc., must be certified by a signatory.
The fixings for replacement fibreglass panels should have the same positions and must have at
least the same strength as the fixings used for the original panels. A combination of steel and
neoprene washers of a minimum 20mm diameter should be used with all fixings.
Seat and seatbelt anchorages, door hinges and latches must only be affixed to fibreglass
panels, floorpans or bodies that have been reinforced to take the loads such components are
capable of generating both in normal use and in a crash.
4.3.2 Fibreglass and Other Composite Replacement Panels
Original bolt-on metal bonnets and mudguards for pre 1971 (ADR 10) vehicles may be replaced
with fibreglass or other composite panels that comply with sub-section 2.7, providing the
modification does not increase the rigidity of the front structure of the vehicle and the
collapsibility of the steering column on ADR 10 vehicle is not compromised.
The catches and/or the design of the replacement bonnet must prevent it from being propelled
through the windscreen into the cabin area in the event of a frontal collision.
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP6_Section_LH_Body_and_Chassis_01Jan2011_v3.pdf
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/vsb_ncop.aspx
Links kindly supplied by Zebra
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
