im going back to the track as soon as i get my cage installed next week, new nittos, and adjust my clutch, then should be ready for some more launching.
excellent, I can't wait to see you run some good times
11.04@125 (1.8 60ft-grannied it of the line) in my 4.5L turbo toyota crown. (Mcrearey DOT tyres)
I realize it's not a skyline-but it's Japanese, 6cyl, 24 valve and runs a set GTR injectors..........
As for the radial tyres-Got Boost-it does appear that you are the dude I've pushed back to 8th in the current HPI list (sorry).....Although in a couple of issues the [email protected] I ran at the meeting after that puts me in 6th spot.
What are the Nittos you are running like mate? Currently I'm just using some tall Simex tyres cause they were cheap and tall (engine only revs to 6000 so I need all the gearing and tyre height I can get)-but the 11.37 is the best I think they will do. What $$ did you pay for them, where from, and would you recommend them?
Cheers dude
Sean
Adelaide
MS-75 ,
Don't tell me you have a 4.5 lt landcruiser engine in the crown !!!
I'm interested to know , how much boost are you running in the old truck engine ?
They are very tough engines biuld to last for ever ......
Looks like 10's are just around the corner .
you got it WRXhoon-it's a 1FZ-FE Landcrusher motor. It ran the 11.65 on 14psi-although the MPH was low at 108 as I backed off when it got a bit of a wobble up in the rear in the deep end of the track. (stock bushes in the rear end was the culprit) It had hit 124mph just before I backed off though. Next time out I had it at 17 psi, and had custom urethane bushes on board allowing me to keep the boot in for the whole 400, giving an 11.5, 11.37, 11.88 (too much gas-went up in smoke) then 11.04 on the semi-slicks. However the MPH (124-125) was the same as for 14 psi, so I don't think the 3psi made much difference (probably the stock plenum and cams I think-it's also nearly on the limiter at 125 so will need a change from 3.23 to 3.08 gears for more MPH). The 1FZ is certainly doing the job so far in relatively stock trim (except for a bit of head port smoothing and combustion chamber mods to dro compression)-and I'm getting stuck into more injectors, custom plenum and re-ground cams soon as well. If I actually stall it up off the line next meet it should go 10.90 or so as is.
It was really an experiment to see if the 1FZ turbo idea would work, and it's proving to be far better than I'd expected. (but yes-the weight distribution is average-however the Crown handles like a turd anyway :throwup: and it's only meant for 1/4 work)
Cheers
Sean
It must be one of the quickest 1fz on the planet .
they turbo them in the middle east but they have to push 21/4 ton landcruiser so they can't be that quick but yea they have heaps of torque and you wont blow them up in hurry ...
Yea they would be very heavy at the front of the old crown . How old is the crown ? mid 80's model ? Still auto ?
Cheers dude
Sean
Adelaide
yeah thats me. my nittos are passed their use by date now and with the new turbo and cams in the power is much more on/off and its much harder to get away without bogging or smokin them hard. im hopin to race again friday night on full slicks again but with proper front tyres to match. you'll be lucky to find nitto's here mine were privately imported as far as know. try some bf goodrich drag radials.
Sean
Perth
Cheers 2RISMO-I had a look, but unfortunately they're 16inch-and I've got 15inch rims-
Has anyone on SAU got experience with the BFG's? I'd be curious as to their impressions.
The ones I had in mind are the 275-60 DragRadials (I borrowed a 275 60 Comp T/A to check sizes and they fill the guards perfectly). I just have to flog off a spare turbo I have to fund them. I'm planning on fitting the car with custom cams, the two new Tial 38mm gates I just bought (it runs two w/g's-one for each half of the split-pulse turbine/manifold set-up), tuning it on jungle juice of some form to about 20psi and fitting it with the drag radials for a crack at the radial tyre record for 6cyl rwd in HPI by the end of the summer. (10.4 is bloody moving though........and I may just end up with a 1FZ block filed with mangled engine parts instead :boohoo: )
I'll probably be hanging around here a fair bit as the skyline community has got a lot of valuable experience with big power turbo sixes. At the moment I'm investigating what would be a good cam profile for it-who is the expert on such matters around here?
The toyota crowd is (for the most part) more into the sprinter/celica 4cyl side of things.(slowly changing though with the 1JZ-2JZ becoming more common).
Anyway-take it easy-and I'll stop clogging this thread with my garbage now. Nice to meet you fellows. (although I'll start clogging other ones no doubt...=-)
Sean
Adelaide
  • 1 year later...
My first time ever on the strip, R33 gts25t typeM. full trim. BP ultimate. 10psi. using my 18's with kumho street tyres 265x35x18 :(. coudlnt fit my spares in my boot. so i just let pressure down to 26psi. will definently be back , chasing 12's with a few new mods and some decent tyres. im sure the car has a low to flat 13 in it, if i could just launch it properly. still yet to get it tuned yet, all mods done myself. only spent well sweet f*k all on the car so far.
FMIC
AVC-R black.
Pod K&N
HKS super Dragger from turbo back. 3" to 3.5ish
react time:1.121
60ft:2.180
660 spd:80.62 MPH
qmET: 13.935 @ 102.58 MPH
Edited by silverbulletR33
1st time at drags, at the SAU vic drag day Heathcote... was dissapointed not to crack into 13's...
Was in low 14's all day.
R33 Gtst, 12psi, safc, exhaust, intercooler 192rwkw...
14.13 @ 106.61
60ft 2.4...
14.18 @ 103.66
60ft 2.39...
mixture of poor driving + poor tyres still on from japan (255's bridgestone playz) explains the 60fts i guess. Although everyone was saying it was slippery and even the 4wd boys were getting some wheel spin.
Reaction time .123
60 foot 1.963
1000 foot 11.173
ET 13.354 MPH 103.23
Cheap Street tyres Bridgestone G grid or something. 215/65/R15
Second timeslip is just to share my fluke which won me some coin
  • 4 weeks later...
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
