Item: R32 non-projector Headlights w. clear lenses.
Item Condition: Very good, slight dimple where headlights have been hot
Reason for Selling: Parting out
Price and Payment Conditions: $300.00 ono
Extra Info: Will include bulbs.
Pictures:
Item: FRP Bootlid, not china shit hand made in NZ
Item Condition: Will post
Price and Payment Conditions: $400.00 ono
Extra Info: Extremely good fit, amazing quality, painted black. Bood lock and latch can be installed, metal behind where hinges bolt up.
Pictures:
Item:[/b ] [color=#1C2837]Kakimoto Regu 06 (suit r32 gtst / gtr) w. [/color]3" SS dump pipe w. flex joint and Highflow Catco Cat
Item Condition: Very good, apart from usual dings / scratches (see pics), comes heat wrapped in sections.
Reason for Selling: parting
Price and Payment Conditions: $450.00 ono (f**king cheap)
Extra Info: amazing exhaust, very quiet.
Pictures:
Item: UAS style (possibly Silkroad) R32 gtst/gtr upper camber arms
Item Condition: Good
Price and Payment Conditions: $150 ono
Extra Info: Good, were modified for longer LCA, can revert to standard by cutting washer slot (see pic)
Pictures:
Item: R33 Clutch Master / Slave w. Braided Line
Item Condition: Great
Price and Payment Conditions: $150.00 ono
Extra Info: $100.00 worth of braided line
Pictures:
Item: Dmax Style R32 Rear Overfenders
Extra Info: there about +20mm
Pictures:
Item: Dmax Style R32 Front Overfenders
Price and Payment Conditions: $100.00 ono
Extra Info: there about +20mm Front Passenger has crack / indicator slot broken (can be fixed)
Pictures:
Item: Clear Indicators
Extra Info: chip from bottom corner, slightly tinted.
Pictures:
Item: FRP gtr style front bar suit GTST
Item Condition: Excellent, few cracks in lip
Extra Info: this is not cheap shit FRP, this is an extremely well made front bar, had bonnet pins in it for quick removal. Painted Black with Bumper trim black Lip
Pictures:
Item: R32 Coupe Vertex Side Skirts
Extra Info: there painted black
Pictures:
Item: R32 Vertex Rear bar
Extra Info: painted black, comes with reverse lights
Pictures:
Item: Personalized Plates
Item Condition: Good, one was involved in accident, but bends straight, new plates are $70
Price and Payment Conditions: $500.00 (what i payed)
Extra Info: FAP 32, epic plates so many compliments
Pictures:
Item: Enkei RPF1 MAP (the light weight one these are 8.9kg each)
Item Condition: Immaculate, tiny mark on one rim.
Price and Payment Conditions: $2000.00 ono with tires
Extra Info: 18x10.5+15 - 265/35 Falken 452's
Pictures:
Item: R32 gtr rear windscreen
Extra Info: gtr windscreens supposedly are lighter.
Pictures:
https://www.sau.com.au/forums/topic/382538-parting-r32-gtst/
Hi, I am after a lot of small bits - if you have them for sale and will post?
screws that hold down the plastic panels that are under the wiper arms,
centre vents,
triangle trims that sit inside the door and cover the mirror bolts,
bolts and screws that hold down the kick panels and hold ecu in place,
door sill garnish clips,
clock,
top demist vent grills - and
steel plate that goes between boot and cabin (behind seat)
Cheers
hey steve.
anything like screws you can get exactly the same or close to from any specialty bolt shop. i do have a pair of the triangle trims that cover the mirror bolts. and no for the rest sorry.
wide body front and rear guards SOLD !!!
Camber arms SOLD !!!
wheels SOLD
vertex skirts - $80
vertex rear bar - $120
rear screen - $280
bootlid - $380
number plates and exhaust system still here.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
