Well it's not a step forward for gamers!
Only gains you'll get are video encoding or higher/multi load tasks over LG1155.
Im not gonna both with waiting till Ivy. It's still 6 months out yet... From what I've read there appears to be a LG1155 chip coming in Ivy, if this is true then that's sweet.
Although who knows with Intel. The LG1366 was meant to be the flagship for ages and the i7 2600k is on the LG1155 and not LG1366 like i expected (this is going back 3 years or so now), and now SB-E is LG2011
All over the bl00dy shop
  • Replies 47
The 2600K is not the flagship though.. i7 990X still is (for some tasks)
Sandy Vadge is for mainstream users who want performance at the right price.
It's just a little funny how well even a supposedly weaker 2500k will take the fight to Intel's $1k+ 6-core monstrosity..
2600k is 1155 socket, not 1366 - that was my point.
It's a i7 label but on a 1155 architecture. There was no indication i7 was going to that socket early on in the days of the i7 920. i3/i5 was meant to live there is what I mean and the i7 to be the enthusiast on 1366.
Im glad i didn't end up going to the 1366 back a while ago, would have been a shot in the foot really as 1366 is effectively dead.
Try buying a 6 core 1155 ;)
LGA2011 will replace 1366 soon anyway.
Not sure if I need 8 cores though...haha, need, sif not get 8 cores.
Edited by DivHunter
Why not be a man and water the cool cpu, can get a good full kit for about $160 to get you started, been running mine water cooling system for about a year know and would never go back to air cooling! There is something about having a radiator in your PC...
+1 On the water cooling, I would get this....
XSPC Rasa 750 RX360 Universal CPU Water Cooling Kit - $199 from PC Case Gear.
I got the XSPC Rasa 750 RX240 kit, the biggest bonus is it drops the temp of the whole case down coz there is no hot air in and around the mother board.
A 2600k will do 4.5ghz on air, more than my E8400 does not on air!
Really cant see a reason to water cool
That is still rather impressive on air, what temp is your motherboard getting to?
Edited by pfcr33
I don't have a 2600k... Yet haha.
It will be hitting 4.5ghz as that seems to be the common result for most chips on the latest stepping. So I realistically cannot see mine being much lower as long as I get all the supporting bits.
My E8400 however sits @ 4.1ghz 24x7, and has since Nov 2008 :)
Was @ 4.3ghz but when the ambient is about 27-28c it gets angry at me. Not sure about mobo temps, either way they aren't high as I've not really changed them. Only alteration is the vcore which is 1.32 @ idle and 1.28 @ load so a bit of droop, but nothing overtly worrying for what was a mid-range board back then.
haha dont mind my lake of sleep before makin that rather dumb commet
Thast good, everytime I have tried to overclock my i7 950 the thing might run nice for a week or two then is cranky to start so set it back to standard, seams to be to the point now if I change anything it just wont start
What voltage did you use?
im guessing too much lol
I will have to see if I can find the spead sheet I was using other wise I would have no idea, One of the things I read somewere was to increase certain settings by 10% then 15%, I think it was around the 20% mark I had problems, as I realy had no idea wtf I was doing, I figured it was time to give up while it still ran lol
any need for the 6970? there is heaps of articles now about the 6950 just needing a flashing of its bios to be the same as a 6970.
any particular reason other than OCing as why you have gone the i7 over the i5 2600k, i am looking at the i5 thats all....
i7 has 2 threads per core, plus 2mb more cache. Means virtually nothing for gaming, but some programs that use hyper-threading are much faster.
Also only some 6950's can be flashed these days, most now have the shaders lasered off. I was one of the lucky ones, but these days it's a bit of hit-and-miss.
The 2600k is i7 branding also not just i5.
http://ark.intel.com/products/52214/Intel-Core-i7-2600K-Processor-(8M-Cache-3_40-GHz)
Same price too, why not i say!
RE: 6950 - ye been reading up on that recently.
I might hold off till more is known about the 7XXX series, some rumours starting to leak now so hopefully more solid info in coming weeks (month).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
