  • Replies 102
Dude, As if I dont know where these cars came from , or thier history's. I know Nathan well enough to know. Its not the point. I dont care who built them. Ovaboost put in a effort to have several cars there as a organised display, and went out and raced hard. Asides from alot of "secret sports" stickers on various cars, I didnt see a real Xspeed precense. Was Hanson there? Ken didnt have a display, yet came and spent the day talking and socialising. Jash put in 4 cars, SST in the form of Steve and Ant where there all day talking and racing - hell Ant broke his box, went home , fitted another, then returned. Thats committment to the scene. And in the end of the day - no scene, no business for anyone, right?
Tomj,
OK, I can see what you are trying say, happy with that. I just like to see the loyalty to whatever workshop you belong too shown and keep. Having one workshop claim work for another workshop is wrong. My 2 cents worth. To all those workshops that did show up BZ and WELL Done. Their suppor for this type of event is always appreciated. Again thanks to Paul for all the work to get SUAWA there. I had a ball. Now I want more :headspin:
I would of loved to be there flying the antilag.com flag and SST(if steve would of allowed it). I find the excuse of road tyres to be somewhat moot as far as I recall GOTBOOST was running on Nitto's and still did amazing times with a fantastic hook up..
Quote of the year
All it takes is a bit of patience, persistance and maybe some concentration on other parts of the car then power though I guess the easy way is to cry wolf and go straight to slicks
It took me 3 months of constant racing and playing with the set up of the car to even break into the 1.9's 60ft's other then that it was only my power making me fast as I was averaging 2.0-2.2 60fts and very low 12's to high 11's ET's as soon a I done a 1.97 60ft I ran 11.7 so my advice is keep at it and try different things and soon it will come together
Brett
and i still might get another meet out them. ITS ALL GOOD
even been questioned on my timeslip because it has AWD6 class  lol
awesome times GOTBOOST, keep flying the 32GTst flag mate!!
what size Nittos are you running?
Chris
So they/you dont have enough confidence in your own work, that if you take it down the strip or on the dyno it wont succeed? Why even try then? I dont get the reason to create these cars then, cept for a shiney photo and blurb in a magazine. That said though, well done on the times on the weekend, nice tyres.
Immacul8 funny you said that about go the rotor, thats what ill be doing.
Cheers
Sean
C'mon dude I was there putting my car where the dyno sheets say it should be. I was a tad pissed off with the AAH, but shit like that happens.
Jash
Dude,
If you knew anything about the cars that supposed to be Ovaboost then you wouldnt have make the comment above. Ask who did Nathan's car and the R34 GTR. I think it'll open your eyes. They are Xspeed cars. I was also there for Xspeed workshop.
You sure there Xspeed cars?
hello all
I have Videos of Drag Combat if anyone is interested
Heres a list 137Mb in total
They are all 640x480 mpegs and have no zoom (taken from a digital camera)
If anyone has any ideas where to upload?
anyone wants them let me know
180 biggest warm-up 7mb
ballistic vs blackrex 7.7mb Blue Rex 12.7 run
R33 33 vs Cefiro1 5.4mb
R33 33 vs Cefiro2 5mb
Brett R33 vs Paul R33 (semi final) 6.1mb
BlkR33 vs silverR33 6.0mb
BlkR33 vs whiteR33 5.8mb
BlkR33 vs R34 6.3mb
BlkR33 vs sil80 5.8mb
C-red 33 vs R31 6mb
C-red R33 vs R31 start-stop 4.9mb
DC5 & B18cCivic warm-up 1.7mb
DC5 vs B18cCivic 6.25mb
GotBoost vs 31 (final) 3.6mb
GotBoost warm-up 4.2mb
NFS vs 32 4.7mb
NFS vs 33gtr (final) 5.2mb
NFS vs DC5 start-stop 17.9mb
Paul 33 vs R31 6mb
WhiteR33 warm-up 2.9mb
s15 vs s13 5.7mb
s15 warm-up 6.7mb
sil80 warm-up 3.6mb
Supra vs Lancer 5.2mb the supra 11.2 pass
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
