so my m35 stagea didn't start the other day. the normally noisy fuel pump is clearly not priming when i turn the key so i'm almost 100% certain that it's dead. I've pulled the plug on it and checked that it's getting 12V (which it is) so it's a pump problem, not an imobiliser or supply problem.
Sorry for the fresh thread, but I've searched and i'm still not entirely sure what the best way to go is for a replacement. I found nissan factory replacements for ~$400, too much info on scottym35's twin pumps, but nothing concrete on the "right" way to just replace my factory pump. I'm not modding anything else at this stage so just a standard or slightly better pump is fine for my needs.
I'm thinking walbro as i understand i can just get the walbro 255 GSS342 for 350z or infinity and retro fit it with minimal complications - is this true? what about the bosch 044? is this a similarly easy installation?
also, where's the best place to source one? i'm in no rush so i'm happy to buy online and wait a week or so but i don't want to get an ebay fake like the ones that were floating around a while back. can anyone recommend a good local or international store?
Any advice on the installation? i'm keen to do it myself to save on labour and towing but obviously playing with the fuel system is something that i want to get right...
Thanks guys
https://www.sau.com.au/forums/topic/382957-m35-aftermarket-fuel-pump/
I can get a Walbro through my Aus wholesaler for under $140 I think so shipping from the states probably isnt worth it. There are definitely fakes around so be very careful. It will need slight modding to install and you will need to rewire the power to it as Walbro's need constant 13.8V.
I have a factory pump here if you need one. PM me. I cant guarentee how long they will last but mine wasnt noisy when I took it out...
Where are you located?
located in sydney's lower blue mountains...
looking at a few guides for installing walbros into 350zs (i can't find a guide for an m35), a factory replacement would be good. i have the skills to do the job, but i don't think i really have the time to get it done on the weekend along with everything else i need to do :\
Try this one http://www.m35stagea.info/forum/viewtopic.php?f=6&t=259
Yeah I was looking at doing the Deatschworks pump. Is that what you're running Tom? Looks like they're the same size as a Walbro, so the fitting etc should be the same.
Is there a filter worth replacing at the same time? I thought there was a screen or something?
Hey mate; I'm at Faulconbridge! Is yours the White Aero kit that I keep seeing around Glenbrook?
If you need a hand, or feel like a chat (or beer); shoot me a PM yeah?:thumbsup:
Cheers, Dale.
Edited by Daleo
its on my to do list
along with many other things :(
  • 13 years later...
Hi guys,
Sorry to revive such an old post!
The fuel pump in my M35 has finally given up, the car has been sitting for 3 years so I'm not surprised. I bought a Walbro GSS342 of Scotty some time ago, so I'll throw that one in. My question is, if my car has no performance mods at all, do I need really to mod the wiring to supply constant 12V? or will the new pump be just fine at the reduced voltage at idle?
Thanks guys..
It will be fine.
The real question is whether the existing wiring is fat enough for the current drawn by the bigger pump. The 342 is not that hungry, but it will be well worth pointing an IR pyrometer, or even better, a thermal camera, at the pump hat wiring when it is running, just to make sure. Or, you know, just touch it to see how hot it is.
  • Like 1
The wires look to be a healthy gauge, more than I would think the pump needs. I guess another concern is if the FPCM will be happy with the extra current draw. I have heard they are a bit sensitive.
If it dies, then bypass. The task isn't difficult.
I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
  • Like 1
I assume the modules are similar enough, so if you've had no issues I don't see why I would.
I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy :)
There would have to be hundreds of posts on the topic of doing the direct wire mod just on SAU alone. Just search SAU specifically, using google, and you should find stuff. Even just recently I have posted excerpts from the wiring diagrams, which are also all available, and discussed exactly how the FPCM does its job - mostly wrt how it interacts with the ECU/ignition wiring. But still, the info is there and relevant. Just search for posts by me on the topic in the last several months.
  • Like 1
I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂
I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram.
Thanks for your help mate, your time is greatly appreciated.
