My car was fine a of yesterday afternoon. I went to work then started it up after that. Car read 100 knock on startup. I reset my power fc max values and now my knock sensor will not read 1 or 0. It sits on 3 to 4 and tiny idle revs will raise it to 10. It is always hearing something. This is bad as I can no longer use this reliably.
Everytime my car starts it gets 70+ knock. It hasn't done this in a very long time, since my fuel pump failed.
Any ideas? Its an rb25det unopened.
https://www.sau.com.au/forums/topic/383205-car-knock-sensor-issues/
Ill be tightening anything I feel is loose, including the knock sensors. Apparently they should read 4v so ill test them too. They are picking up CONSTANT noise. No more sitting at 0 or 1, they are always on at least 3 when just idling and jittering up and down when touching the throttle.
70+ on startup would indicate something to do with the starter motor. while the car is running there may be some vibrations through the starter causing knock readings. i know i get the most knock on startup sometimes. Its not so bad when i stop cranking before the engine has fully started so the starter motor isnt being over-run by the engine before disengaging the ring gear
I know my starter is on the car tight so its either a bit funny internally or maybe the thin plate on the bellhousing is vibrating with the starter motor
My starter motor is fairly tight on there. I just pulled out the first knock sensor, its still reading the constant values. There is no way in hell I can reach the second one at the back of the motor so I am going to check the pinout on the ECU and measure the voltage of both of them. There is nothing I could have done to cause this which is why its annoying me.
Yesterday I got it to read 90 knock with the fuel and spark disabled from the fuel pump and from the coil packs. Today I disabled everything my removing the CAS wire, and it wouldn't knock no matter how long I cranked it. I plugged it back in and on the first engine turn, before it started spluttering or coughing, it read 100knock. I hope there isn't something wrong... If I could reach that rear knock sensor it would be sweet because then I can pinpoint the fault at the rear knock sensor or noise coming from the rear of the block.
I just accidentally, and probably subconsciously intentionally, ripped out the wire from the rear knock sensor. No more funny readings. No more high knock readings, no more constant readings.... And now no more knock sensor watching the back 3 cylinders... f**k. That clip is f**king impossible to get to. I'm going to buy a second hand sensor and try get the old one out and a new one in.
Edit: f**k AGAIN. It just read 60 knock on f**king startup. The knock sensor must be too far from the rear of the motor to pick up that other noise the rear one was picking up. Now I f**ked my rear sensor for nothing. FUUUUUUUUUUUUUUUUUUUCK
Edited by SargeRX8
Can you try another CAS? I just replaced my CAS because the bearing was on the way out and making alot of noise. Have had alot less knock since then, but my base timing is the same as it was with the old CAS
try and borrow one and see if it helps. If your knock reading goes down then you might need a new CAS.
If you havent touched your tune then it sounds a bit like something has partially failed. Just suggesting CAS, cause mine was very intemitetly throwing out high readings which werent really repeatable
I have not changed anything in relation to the tune since this started. I installed my wideband sensor into the stock location, replacing the old narrowband and that was it. I do feel my CAS may be failing due to starting issues but do not have a spare to test it. The noise is being detected from the rear so I am leaning towards gearbox or starter noise. I don't get false readings when driving, only the startup knock and like the hummmmmmm which reads 3+ knock all the time(which now isn't a problem since I snapped that wire lol).
Most read a bit of noise when idling and revving. I wouldnt be too concerned with it. Throw it on the dyno and finish the tune by listening and without relying on the power fc knock reading so u know its right.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
