The Ash megaphone wake up call needs to be repeated
Yeah you kents can GAGF'd if you think I'm gonna fall for that twice...
Late night megaphone calls whilst answering the phone asleep... Not cool lol
  • Replies 45
Hmm EC not looking good for a double header that weekend they ahve a bike event on fri - sun
http://www.motorcycling.com.au/PDF_Files/Competitor_Info/ci_sr_2012barrysheenefos_201211.pdf
next track day there is the friday after not staying up for that long.
Wakefield ahve the nissan sports car club there the following day:
http://www.wakefieldpark.com.au/event-details?event=288
and they seem to imply they are only $80 for the day:
http://www.nissansportscarclub.org/index.php?categoryid=35
I might hit them up and do a half day there.
$80 cannot go wrong.
Barry Sheene memorial event, feeling old here, I used to go with my dad and watch him race in the mid 70s.
Hi Martin, As for wakefield sprints, as we're SAUVic not SAUNSW, does that mean $250 entry, just wondering if you've already clarified. As for Nissan day, don't they mention you also need to be wakefield member therefore $80+$40 or is that similar to Winton having the possibility of an AASA in lieu of CAMS L2S?
Martin that info is pretty out of date on NSCC, they still have Oran Park listed, and the prices are 3 years old. From memory the NSCC days are about $150 odd but heaps of entrants (60 or so compared to 35/40). You'll feel cramped compared to the day before. If you want variety on the second day (or even the day before, whatever you're doing) have a look at Marulan (MDTC), you can ring them up and tell them you're coming from Victoria etc and see about getting on there. It's less than an hour from Goulburn accommodation and generally easy to get on to
Guest
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
