  • Replies 44
they are using those chrome coatings on drag cars and motorcross pipes, so I reckon it must be pretty good, even some of the professionals use those coatings like motoGP bikes and pro motocross as well as heaps of drag cars...
ye, but those guys don't care if it has to be re-done every 2nd race meet
post a hires pic of your engine bay and I'll shop it with different colours if you want... thats what I did for mine and I had a thread here to help me decide, its not until you can see the colours together on your engine bay that it can considered the right choice I reckon...
oh come on Zebra dont shoot it down... I want the chrome colour look.... Im gonna ask them how the motoGP bike fairs after a few race meets...
I know the commodore drag car they have done the whole engine bay on in chrome hasnt been redone ever and still looks awesome...
Yer thats what i think to. but i cant find anything... the battery the way it is stands out like dogs balls...
Was thinking of getting some stainless steel and making something when i make the box for the pod
I think because there is some black in the bay, electrical and vacuum hoses, that the contrast of the blue isnt enough.
so maybe reduce the black, easy way and cheaper than replacing or cover all of the tired look hose and wire coverings could be to use stainless steel sheet to cover all except engine, fuse box, air intake. that would make the engine the focus so any colour would 'pop', custom box, or arc intake box and cool fuse box cover. the only other thing you would see is the strut brace and possibly use some venting on the stainless covers to keep things interesting and functional heat wise perhaps...
that would tidy it up, give it that custom show look, easy to maintain and nowhere near as expensive as colour coding or replacing a heap of other stuff... definitely have a wow factor when you open the bonnet... i'll shop it up and show u...
kinda like this....
maybe a tad more space around engine to allow for some movement, but this way it keeps the focus on the cool stuff and makes it so you dont have to keep all the wiring and hoses in mint awesome condition to have a wow factor bay....
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
