  • Replies 125
hey guys i didnt want to start a new thread for one question so while we are on topic of ecu's my ecu has wasted spark feature what is wasted spark and whats its good for
Oh come on, what about google!?
I'll throw you a bone though. Wasted spark means the spark plugs fire in pairs. So one sparks during the compression stroke and the other sparks during the exhaust stroke. That spark during the exhaust stroke does nothing though, hence 'wasted'. The benefits of this is that you can halve the number of ignition components that you need, so on a 6-cylinder car you can use 3 coils, etc.
after many hours reading and downloading / playing with all the software etc
I have narrowed it down to 2 ECU,s
The Haltech PS2000 or the Adaptronic E1280
Both are around the 2k mark, So double what I originally wanted to pay, they both have cheaper options at a bit over $1k, so I have to decide if I really want sequential injection and ignition.
The decision for either of these came down to both the ease of use with the software (not saying the others are hard) and they can both be tuned via Speed Density.
Which for me doing the tuning myself makes it much simpler, I still think the Haltech software is the easiest/best laid out to use between the 2.
So we shall see
Edit - wait a min!!!! I disregarded the sprint 500 for its lack of big enough on board map sensor...just found out an external one can be fitted.
This changes everything!
Can now get an ecu under $1000 that also does VE/Speed density tuning!
Volumetric efficiency - you tell the ECU a target A/F ratio, engine size, the approx VE and injector size, it works out how much fuel to squirt.
then adjust the VE to get the fueling spot on
Pretty much means you can guestimate the VE to get the car started and mobile, then adjust from there, instead of working out injector pulse times
I'm sure someone will know more than me, but it is how they tune both R35's and LSx V8s with flash tunes
G4 Link ECUs can be configured to similar effect - not quite as refined as that, but still a lot nicer than just having an outright pulsewidth table.
Firstly, the fuel tables when using MAP as the load value actually are mapped relative to atmospheric – so you effectively are mapping all load zones as though they are at “sea level” atmospheric pressure, then the ECU calculates up or down based on what the load line actually is. If you see a G4 Link fuel table with numbers roughly twice as big around the 200kpa load zones as at 100kpa, then there are probably quite serious issues with the tune.
Secondly, there is a mode called “Open Loop Fuel” or something like that (I don’t have the Link software in front of me) which when enabled – does a similar type of offsetting, but this time it treats ALL fuel values as though you have tuned the entire map to suit stoich. The ECU then refers to the “Target AFR” table which is normally used for self tune and closed loop lambda to scale the numbers up or down to suit the actual target AFR you require for that load cell.
Sure, its not as nice as speed density tuning but really to me the main benefit for SD tuning, and this for that matter – is that you don’t have a map which is “all over the place” due to required pulsewidths going up in non-linear fashions due to load and AFR targets. Makes mapping that much easier, and you’re going to have to piss around with the base numbers a bit at various load levels regardless to get them running nicely.
Cheers. Do you happen to have a g4 map for me to look at? Doesn't matter what motor.
The SD factor just appeals to me because I decide to wire in an ecu I would need to easily get it running and do the low load points quickly
No doubt full throttle isn't all that much different between SD and inj pulse to get right
I do hear good things about going from a pulp tune to e85
Change the target afr and off you go. Or the adaptronic let's you change the lambda figure and go
I might have a nosy later and see if there is anything I feel like sharing, as I use that mode in all the G4 tuning I've do - as well as other fun things you might find interesting such as switching fuel and ignition maps in real time (on VTEC Hondas) etc. Fwiw when you download the G4 software you get a bunch of sample maps anyway - SOME of those have the open loop fuel mode enabled as is.
Can't really comment as I've not done an SD car yet, though the G4 cars I've done have typically taken similar or more time to get other configuration bits sorted (that aren't specifically fuel table related - ie, cold start/accel enrichment etc) than to actually get the car running and driveable.
Same would apply for the G4 with the method I described of course, with the added advantage that (providing you configure the O2 sensor setup correctly) it also has support for using input Flexifuel sensors for fuel and ignition trim ;)
Ye, I do really like the Link/Vi-Pec ecus.
not a huge fan of teh software, PC-Link is better than the vipec despite been 99% the same
Im sure that is more to do with me playing with every available ECU software that is out there lol
The Adaptronic software is fine on a 19" monitor...not sure how it would go on a little note book though....too many small tabs to click on
Yeah thats the puppy i want...tempted to palm of my PFC for one... :thumbsup:
Its the one HG sells with the turbos isnt it..Is there a plugin loom for skylines?
or is it this one im thinking of
http://adaptronic.com.au/products/selectpnp.html
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
