  • Replies 83
Posted Images
sad.gif hmmm thats not cool. the plan for the moment is to keep it as simple as possible and then as funds permit, slowly rebuild the dead engine we pull out ready for the day when the engine we put in dies lol
current engine has a REALLY bad knock. had ESP have a look at it and they said definitely a rebuild and to budget for between 12-15k. current engine was rebuilt about 25000k ago in melbourne, so forged internals, r33 crank, n1 oil and water pumps, and also n1 block, reconditioned head. unfortunately not being incredibly mechanically minded, at least when it comes to the internals of an engine, i'm relying on what places like ESP are telling me
Hey! Just noticed you're in Banks....mighty close to me....in fact if I listen carefully I may be able to hear you typing.
Depending on what went wrong with your current engine, if may be better to rebuild it (a basic one)
Forged Pistons and rings - ~$1000
standard rods are fine for 400rwks
New bearings ~$300
Machining/assembly - ~$1000 maybe a bit more
New Nissan head Gasket - ~$60
and Oil Pump - $500-1300 depending on what you want
and should be good to go using the old intake/exhaust gaskets
Edit - just read your last post...if that is all done already definitely rebuild it.
may only need new bearings and give the crank a quick machine, or buy a 2nd hand crank
if yours is the black on black soarer then I've spotted you a couple of times in the last 10 months since i moved down this end of town.
current engine lost oil pressure very suddenly cruising at about 150km/h and instantly developed a nice clunk.
i would be more than happy to get this engine rebuilt if it was going to work out to be about the same price as the swap we're thinking of doing.
our budget for the swap is $7000. so thats $2500 that ESP quoted us to do the swap and then about $4500 to purchase an engine.
the things I'm most worried about are we don't know how bad a shape the current engine is in until its opened up and who do we get to do the work seeing as i can't do it myself
Ye that would be me in teh Soarer :)
If you can pull the motor out yourself with the help of a few mates you will save yourself a metric butt load of money.
You have a fair budget for it, so providing you can get the motor out you will get a reasonable RB26 for $7k, if the pistons and rods are re-useable you will have change left over.
I suggest you go and speak to Greg at pro-engines in Queanbe-hole
http://www.proengines.com.au/packages.html
wow i have never even heard of that place before. might see if i can duck out from work tomorrow to go have a chat to this guy.
id be more than willing to pull the engine out with a few mates but the main problem i have is that i have nowhere with enough room lol
:/ Drew.
Honestly if your block had the above done I'd go straight to rebuilding it. Check the side of your block to confirm it is an N1 first.
People who spend money on these would normally have the rest of the job done properly too. Makes me surprised it's blown so soon.
It's either had a real flogging/lack of basic maintenance or wasn't built quite right.
The obvious down side to you is the time your GTR's off the road.
The upside is you have just about enough to get the rebuild done properly and the time to get the rest while it is being rebuilt.
As Andrew said try and get the block out with a few peeps off here and save yourself a few grand.
BTW. 12-15 grand is a bullet proof build with everything replaced and nothing re-used.
You have put some really good thought into your options already. Just thought I'd sum it up.
Cheers Richard, I really appreciate the time you guys have spent helping us out.
I've got receipts for the rebuild that total nearly 20 grand so we were very shocked when ESP told us 12-15 grand to rebuild it. I'm hoping to get out to the place in queenbeyan that zebra suggested last night to have a chat with them. So we'll go from there.
Unfortunately I don't have the space or know anyone who has the space for me to be able to pull out the engine so we may have to factor that into our costs of the rebuild
If your looking at getting your engine rebuilt I'd also look at sydney. As there is a wealth of knowledge up there as well, and I think your limiting yourself if you don't at least consider getting it done up there. CRD seems to have a good rap up there. Having sorted out a lot of GTRkats issues with her rebuild.
I've definitely thought about that, even to the extent of talking to CRD on the phone. The main problem we faced though was actually getting the car there as we don't have something capable of towing a car trailer. That's the only reason we've decided to get it done in Canberra.
Speaking of Canberra, I went out to the place that zebra suggested and it didn't look like it had been used in a while. The front gate was open but everything else was shut and nobody responded to my knocking or phone calls. So I went and had another chat to Glenn at ESP and the car is now going into the shop next Wednesday to have the engine pulled and stripped down to find out exactly what needs to be replaced/fixed and how much it's going to cost.
If anyone on here has the space, time and know-how between now and then to help me pull the engine out then let me know! Lol
Seriously though....help!
Keep the advice coming guys.
Cheers,
Drew
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
