  • Replies 41
was thinkin bout this one...
Its supplied by electus distributions who are the wholesaler for most of Jaycar's products, they have a special right now for 3 CB radios,a nd I think this one was $25 or something... bargain price really....
maybe we should organise a group buy for before the cruise
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777004
Boyz If memory serves me correct those UHF are a POS! For $25 I can guarantee that yes it may cover the 5km range but It will break out alot and wont be clear...
acsplit arrange the group buy a while back as his work sells them... spend the $90 or so on one of his as they are quality.. I have one and have used the ones your looking at and there is a huge difference in quality
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777460
http://www.dansdata.com/digitalk.htm
and
http://www.strathfield.com/Product.asp?ProdID=201
Contacted Electus, turns out its the same CB but the older housing (ie its cosmetically out of style) hence why they're clearing em at $23... and for that price even if it only works for 500m its f**kin awesome.
Jaycar is still sellin em at $42
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777547
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
