curbsurfer, ive been playing with a 2530 for a while, and IT IS TOO SMALL FOR A RB25!
The very most you will see is 230rwkw, and you wont be able to run more than 14psi at the top end as the rb25 has too much exh gas flow in the high rpms making the compressor spin out of efficiency and boost drops off, and intake temps increase and detonation increases. It is not correctly matched for this engine, and suits an RB20 perfectly, not a 25.
That said it is still fun to drive and spools like nearly stock, but after your used to the extra midrange torque, the lack of top end kick makes it a bit boring.
a 2535 should give you 240rwkw and the 2540 250rwkw. HKS japan website has dyno graphs for these turbos on a rb25 and you can see that overall the 2535 looks like a great match. The 2540 ove been told is the best if you are going to fit cams to boost the midrange a bit.
Its pretty awesome, It doesn't have cams though.. Full specs are in the For Sale section.. It is a real blast to drive on the street.
It also has the stock plenum & stock manifold (the 2540 is probably the largest low mount turbo for the RB25DET) - Helps when cops pull you over...
check out www.geocities.com/r33forsale for under bonnet pics
51jay when you say it may be laggy on a stock r33, what have you done to yours that makes it not laggy?
also to mose, would you say yours is at all laggy?
272rwkw is a lot more than i thought it could make! thats a pretty big figure for a smallish turbo. Didnt grepin get only mid 270rwkw's out of a 2835proS?
51Jay what power does yours make at the wheels?
i was going to get a 2835proS, but if i can get 270rwkw at 18psi id be pretty happy with that!
Popular opinion seems to say it's laggy, It's not laggy in my car. I think a lot depends on how it is set up, mine makes respectable boost on 1/4 throttle and is very linier in it's onset coming on to full boost at 3000 or just under then maintains it up to 7500. I'm using the FC-Data Logit default tune as I have not yet got it to the tuners.
mods are
HKS adjustable camgear on exhaust retarded 4 degrees.... anyone who has this and hasn't got a big boost in low and midrange torque hasn't done it right...no argument!!
lightweight flywheel...6Kg
3" turbo back exhaust....pretty quiet...probably legal
600x300x75 fmic
modded plenum...front throttlebody R33
Apexi Super Suction pod filter kit cold air box
Sard fuel regulator, VN fuel pump
HKS2540 turbo split dump pipe
Power FC
E-Boost
I expect to have around 210 to 220rwKw when I finally get it tuned but i'm more interested in good power and torque right through the range than big peak power numbers
51jay you should make 220rwkw in your sleep with that turbo if i can make 227rwkw with a 2530! I know that the 2540 gets lots of bad wrap, but i think this is mainly from tests done in twin form on GTRs. Ive never heard of anyone running a single one on an rb25 and complained of lag! How could one smallish turbo on a reasonable engine of 2.5 litres be laggy(?), is what i think! Im sure sydneykid has commented on it, but i cant remember his comments, and searching for a specific post from him would take me all day!
I am still wanting to hear from mose about his 270rwkw! either something is amiss or what he thinks is a 2540 is actually something bigger! because to me anything over 250rwkw from a HKS GT25series is so far unheard of!
Its not too laggy at all, quite fun to drive actually.. While I had the engine built, I had a good look at the turbo, it is surely a HKS 2540.. I wanted a street car, not a drag car.. The suspension is very stiff in my car so when the turbo hits boots, all the torque hitting the rear wheels (with the stiff suspension) results in moderate wheelspin.. It is my understanding that Drag cars have much softer rear suspension, so when the turbo hits boost (in a turbo RWD) all the torque hitting the rear wheels is "cushioned" with the softer suspension... (Resulting in less wheelspin)
Personally I would highly recommed it (the 2540) as it a weapon on the road, especially in 1,2 and 3rd...
It is the best low mount turbo there is... I will post a pic of my dyno sheet up soon.. You WILL Notice that the turbo runs out of puff though at that boost setting. It hits 272rwKW then drops down about 8Kw... Keep in Mind that I run Low Boost (14psi = 254rwKw) and High Boost (18psi = 272rwKw) Not a whole lot of difference... I very rarely hit High boost, 254rwKw is still a bit of fun!!
Turbo Tits:
Having fuelling problems with mine at the moment and am waiting on my Nismo adj FPR. It would lean right off on anything over 7psi but I was getting 180rwkw @7psi even with problems (in Shootout Mode). Can't wait to wind the wick up when i get it all sorted. :) Stay tuned...
Those are impressive figures mose... I've only managed 230rwkw's out of my 2540 @ 14psi. Need to replace the actuator to something heavier as I leak a lot of boost in the top end if I go much higher.
But yeah, congrats to anyone who comes even close to that on a 2540... I know I'd be more than happy.
Hi Guys, I think you need to keep this table in mind when discssing 2530, 2540, GTRS and 2835
.....................Compressor......................Turbine
....................Trim...Inducer....Exducer...Exducer...Inducer....Trim
GT2530..........63____1.860____2.344___1.883____2.098____76
GTRS.............52____1.997____2.773___1.833____2.098____76
GT2835..........52____1.997____2.773___2.020____2.204____84
GT2540..........46____2.016____2.972___1.833____2.098____76
Note that the turbines on 2530 and 2540 are the same.
In my opinion, supported by experiences, the 2540 is badly mismatched between compressor and turbine (ie; either the turbine is too small or the compressor is too big). This mismatch exists no matter whether the 2540 's are used as twins on an RB26, or single on an RB25. It is my belief that HKS recognised their mistake with the 2540 and introduced the GTRS to fill the gap created by this failure. To achieve this they have simply used a 2835 compressor with a 2830/40 turbine.
So if a 2530 doesn't give enough power for your requirements, then I would go to a 2835 as they are a much better match of compressor and turbine.
Just to add and further strengthen Sydneykid's point.
A table showing the trim and compressor and turbine diameters can be found at:
http://www.takakaira.co.jp/performance/hks.../gtturbine.html
Here we can easily see here that all but the 2835 share the same compressor housing, and turbine wheel while the GT-RS and 2835 fit inbetween the 2535 and 2540 in terms of compressor wheel trim size. This demonstrates how large the trim is on the compressor side of the 2540 and perhaps explains why many people regard it as mis-matched as sydneykid pointed out.
Given that some people are of the opinion that the 2530 is a little too small on an RB25, perhaps for a mild increase in power while retaining near stock response a 2535 (340HP)would be the go while if you're after more power a 2835 (380HP) or 2835ProS (420HP)would be the way to go.
Just my 2c, plus i thought the link may be useful :P
seeing as the 2835 "ProS" is the only variant that will bolt on, this is what i will be looking at upgrading to.
Mose:
im not saying your car doesnt have 270+rwkw, and i know that HKS's power ratings are conservative and rated at 1bar, but even with you running ~1.3bar i just cant see a 350ps rated turbo puting over 270kw at the rears!
Reading back over grepins 2835proS thread, he makes 275rwkw at 1.3bar, plus he has a plenum! I am thinking that there is a major dyno discrepancy here! what type of dyno did you use? please post the sheet up!
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
