  • Replies 92
I'll tell you now boost, ok so after about
A month of searching and searching something
Popped up that just didn't add up, so I saw this guy always down my street with a very tidy SSS pulsar he was a. Regular guy seemed like a real straight shooter until this one day, I had just got home from work when I heard the note of an RB coming down my street so I waited until it had passed me, this 33 gtst was in a primer and looked like it had been at the chop shop, I giggled and walked down to have a chat with him it just seemed to easy and to good to be true about an hour of talking and pretty much covering the whole car it had no vin number no mod plates had been completely stripped, he thought I was just a regular person I gave him the ultimatum and said now this is how it's going to happen Called dad he sent a patrol around and then shit got real, yes he was charged, my dad being as high as he is in the force can pull alot of strings we had the charges dropped on him but at a price, we received the number address and name of the person who sold him the stolen car, and this is where we are today, we have pretty much everything and every person involved in this little syndicate if you wanted to call it that. We are in the final of it all now. 25 people will be charged if all goes well and ACA is on standby for it
Holy shit that's awsomE news and really good luck that you spotted something out of the ordinary .
Hopefully it does come on ACA and they are named and shamed so that import owners can rest easy for once
This news just made my day hopefully all goes well and these scumbags learn there lessons
We aren't worried at all mate about scaring them they won't get far, I can't go into details to much but there on lOckdown :), evidence is there yes but we are matching which person and car are connected and also if we can find owners of the cars they can place there own charges
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
