there is so much to upgrade on an NA to make it turbo...
if you are going to do it PROPERLY...
you can do the dodgey thing, upgrade nothing slap a turbo on it etc... and end up with a confused car that doesnt perform anywhere near the effort put into it....
sell NA buy turbo car, save time and money, not one spanner needed... done
Edited by 75coupe
Swap block out for a second hand good cond 33 gtst det block - your choice to rebuild here if you want. (u may even be able to reuse ur old block if its got oil squirters for the pistons. If so just whack in det piston and rods, new bearings and headgasket and ur set.)
You will need the complete det turbo and intake setup - turbo plus oil and water lines, exh manifold, dump n front pipes, intake pipe, air filter or airbox, fmic interooler kit, manaul bleed valve.
Whack in a 33 gtst ecu or go pfc (again your option depends on budget)
The difference in the de cams will give you abit of gains compared to det cams.
Since youve got 50% more power, ur gonna need tp address.brakes so gtst brake setup and 5 stud conversion os on the cards.
You will also need to put the power down so a gtst viscous lsd will be needed.
Unless ur car was purchased fpr dirt cheap like 4k then itll be worth it to do the above, otherwise just sell and get an.original gtst as they are cheap these days.
Judging by the post he made last, it looks like a transplant more than a conversion.
Still shit. You've got an NA registered R33 with a turbo motor. Technically, its a huge defect. You will also need to change the brakes all round as the non turbo uses smaller brakes, another $500 to source brakes.
Maybe i'll explain in a much more simpler english since know one seems to understand what i'm saying.
I will swap the RB25DE engine out and replace with a COMPLETE WITH TURBO,LOOM AND ECU RB25DET all i would need to get it going from the start would be intercooler and exhaust. would i not ?
Brakes will hold up, gearbox should hold up for now.
Will be installed by a mechanic so a eng cert will come along with it and car will be re-registered with vicroads with new engine number and whatever else
Make sense now ?
Now what complications will i come across ?
Edited by brat81
Make sense now ?
it wont be eng cert without turbo brakes
Having done this myself...
Endless. Do as the others are advising and sell it.
Unless you have already upgraded the brakes/suspension/drivetrain etc, and you will be making more of a loss by selling the car and buying a factory turbo model then you really shouldn't be thinking about doing this.
For the price a 33 gtst goes for, you would be nuts. Unless you purely want the experience of pulling it apart and reassembling it, sell it.. I dont think a 33 gts would be worth much less then a 33 gtst (purely because the gtst is worth nothing) Sell.
no the brakes wont be fine...
no the diff wont be fine...
then you'll probably find the suspension will be sloppy so there's another upgrade needed...
so not worth it... buy a turbo model
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
