there is so much to upgrade on an NA to make it turbo...
if you are going to do it PROPERLY...
you can do the dodgey thing, upgrade nothing slap a turbo on it etc... and end up with a confused car that doesnt perform anywhere near the effort put into it....
sell NA buy turbo car, save time and money, not one spanner needed... done
Edited by 75coupe
Swap block out for a second hand good cond 33 gtst det block - your choice to rebuild here if you want. (u may even be able to reuse ur old block if its got oil squirters for the pistons. If so just whack in det piston and rods, new bearings and headgasket and ur set.)
You will need the complete det turbo and intake setup - turbo plus oil and water lines, exh manifold, dump n front pipes, intake pipe, air filter or airbox, fmic interooler kit, manaul bleed valve.
Whack in a 33 gtst ecu or go pfc (again your option depends on budget)
The difference in the de cams will give you abit of gains compared to det cams.
Since youve got 50% more power, ur gonna need tp address.brakes so gtst brake setup and 5 stud conversion os on the cards.
You will also need to put the power down so a gtst viscous lsd will be needed.
Unless ur car was purchased fpr dirt cheap like 4k then itll be worth it to do the above, otherwise just sell and get an.original gtst as they are cheap these days.
Judging by the post he made last, it looks like a transplant more than a conversion.
Still shit. You've got an NA registered R33 with a turbo motor. Technically, its a huge defect. You will also need to change the brakes all round as the non turbo uses smaller brakes, another $500 to source brakes.
Maybe i'll explain in a much more simpler english since know one seems to understand what i'm saying.
I will swap the RB25DE engine out and replace with a COMPLETE WITH TURBO,LOOM AND ECU RB25DET all i would need to get it going from the start would be intercooler and exhaust. would i not ?
Brakes will hold up, gearbox should hold up for now.
Will be installed by a mechanic so a eng cert will come along with it and car will be re-registered with vicroads with new engine number and whatever else
Make sense now ?
Now what complications will i come across ?
Edited by brat81
Make sense now ?
it wont be eng cert without turbo brakes
Having done this myself...
Endless. Do as the others are advising and sell it.
Unless you have already upgraded the brakes/suspension/drivetrain etc, and you will be making more of a loss by selling the car and buying a factory turbo model then you really shouldn't be thinking about doing this.
For the price a 33 gtst goes for, you would be nuts. Unless you purely want the experience of pulling it apart and reassembling it, sell it.. I dont think a 33 gts would be worth much less then a 33 gtst (purely because the gtst is worth nothing) Sell.
no the brakes wont be fine...
no the diff wont be fine...
then you'll probably find the suspension will be sloppy so there's another upgrade needed...
so not worth it... buy a turbo model
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
