Hi guys;
So long story short, I thought i blew my turbo up - turns out the sound was my power steering or something (still not sure, taking it to the mechanic next week). Went through ALOT of hassle to put on an rb25 turbo and then cranked the car up to find out the noise that I suspected was the turbo was still there LOL! I actually thought the wheels were touching the housing etc which was all in my frikkin head. Mechanic had a look at my turbo after and said the amount of vertical shaft play is 100% perfect for a bush bearing turbo - ZERO horizontal movement and wheels spin free as anything. So here I am now :P (good for a laugh i guess).
I wanted a better low end response rather then power and I never actually got the car tuned or did anything after i put this on - just lazy.
So its up for grabs - has done around 30,000 km's or so. I paid somewhere around a grand for it, Hypergear can confirm I guess - but thats besides the point, I would like $450 for the lot which I think is pretty reasonable (feel free to correct me if I'm wrong). Feel 100% free to come inspect the turbo before you buy it as I'm not a pro and you shouldn't take my word for it - wasn't smoking, no leaks visible anywhere, blades are fine, came off a running car yadda yadda.
Comes with everything pictured (I might have a few clamps etc i can throw in). I can ship it interstate for $30 also. I'm located in Box Hill.
Let me know what you think - this should work really well on an rb25 (or anything when you spend time and tune the bloody thing :P)
Cheers.
https://www.sau.com.au/forums/topic/384138-tr43-turbo-and-accesories/
Just in case its unclear - here's whats included
- Turbo (no dump pipe)
- 2x silicon joiners
- Braided oil line
- Actuator with hose
- Aluminium intake elbow
- rubber bend (one of the intercooler joins i think)
Items came off an Rb20.
hey mate, is it a 1st or 2nd gen tr43?
I just found out yesterday after someone sent me a PM that there were generation in this, if you tell me how to identify it I can tell you? Pretty sure Stao stopped doing these turbo's shortly after I bought this one ...
thanks mate - yea people have made some decent figures with supporting mods - that was why I got it in the first place. Never got around to tuning it and running some high boost through it =/
lol yeah got those figures without a tune, just bolted it on, chucked it on the dyno, up the boost and just made sure everything was running right.
noticed in the pic there is no actuator or flap, need to supply our own?.. also wondering if you know what profile it is as im after the g3 .82 profile..
perhaps u could email stao with a serial no on the centre cartridge to find out?
if you like PM me and we can sort these out and if all is well ill take it.
ATR43G3 .82 FNT wasn't invented till 2x years after this turbo was built. This is a TR43G1 does not blong to any ATR series, and retired. Its good for upto 250rwkws on a Rb25det with ok response.
