Hi Everyone, there seems to a lot of EPA slips flying around and landing on windscreens and in letter boxes.
Question is which exhausts have passed and which haven't ?
There is plenty of different setups when it comes to exhaust and of course depending on whats done to the engine does have a huge impact towards the configuration of the exhaust setup,
So post which mods you have and exhaust configuration including the Db reading for each setup.
Example:
BMC filter
FMIC
EBC
PFC
split dumps > 3" down > 100cpi cat > 3" > resy > HKS HI power muffler
102 Db
running 210RWKW
All else stock.
I had a Kakimoto catback, 2 large oval mufflers and a standard cat, no chance it would have passed EPA, stock is really your only option on Skylines.
Stock GTR's are over 90 from factory, we are all F#$%#*.
and I thought my 3.5 inch racepace full exhaust was quiet...until it's opened up at 8k
My RP 3.5" (on the 31) is 91-92dB @ 5100rpm. So juuust about legal, but not quite.
Not sure if the GTR version was able to have larger mufflers to get it down further.
Either way enough to have a nice note, but not get attention :)
Well if it's over 90 from factory doesn't it make it legal because it's been complied?
There is a cut off date for the exemption, for instance a 67 Mustang can be 114db and get away with it, just not sure on the exact date.
I wish.....
older than I think it 85 are the older ADR's so we get 94db but that it.
Not to a legal standard whilst maintaining the flow of a straight 3.5" exhaust, decent CAT and acceptable ride height etc etc - on a skyline.
People including myself have been there and tried, you come close, but just not enough.
Another car with a different floor pan, then possible if you could get mufflers on there that are larger again... But 2-3dB is actually a substantial amount of noise to soften.
It's the noise of the motor and the 4700/5100 RPM that the tests are done at that sets the meter off. They also measure "back off" noise too, which often a crack/pop will set the meter off over the limit.
3" you can get passed however, as i said in post #4
So which 3" configuration do know you of that can pass
which dumps, down, cat, res, muff, material, press, brand etc.
The big question that follows is do you have evidence?
I just find it hard to believe that a stock exhaust system on an R is >90db or is that referring to a particular model - 32, 33 or 34.
The standard 34R system seems pretty restricted to me however, the only good thing about it is the awesome flow properties from the manifold and dumps. Do not change them :)
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
