  • Replies 5.5k
Posted Images
did anyone else hear what sounded like Hamilton's car very briefly touching the rev limiter before braking into the final turn?
they've obviously been geared to not have to overtake people under DRS. no wheelspin off the start tomorrow son...
I noticed Webber was maxed out at the final turn as well.
damm you rosberg, i had high hopes for him in quali, cant handle the pace. he needs to take a page out of his old mans book and have a smoke before he gets in the car. vetool almost looked like he was going to cry, how many races can he go without a pole?
Vetool smokes plenty of pole prior to each race....
Button to win, and most likely the championship.
Webber to outrace the 'Tool and place well, once he makes up the positions he loses off the line
Masa to tangle tyres and punt himself out of the race
The old boy Shumi looks like he'll have a good season. McLaren and Mercedes look like they've benefited the most from the blown diffusers being changed. Can RBR find some pace?
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
