  • Replies 5.5k
Posted Images
2 races in a row where Pirellis haven't fallen apart...
2 races in a row where the lottery effect of random people turning up high on the grid and in race results hasn't happened...
I'm tipping they've quietly changed back to last year's compounds. Either that or every team in the field suddenly worked out how to make the tyres last at exactly the same time...
Edited by hrd-hr30
Well it looks like Nando should almost certainly get another drivers title this year. To not, He'd need to start having a heap of shit results, or the Ferrari to lag heavily behind it's main rival's development in the last half of the season. Can't really see either of those things being the case.
I'd love to be proven wrong, but have a feeling I won't be...
Nige and his fkn huge balls at 1:04
webber throwing in his usual no-show
this is exactly why he will not be a WDC
Unfortunate isn't it?
Note to Webber: The best in any profession don't take days off.
Edited by iamhe77
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
