  • Replies 5.5k
Posted Images
Alonso deserved that championship. Vettel is very deserving as well...but Alonso only really lost points when taken out in Spa and Japan...it seems every weekend he got every bit of speed the car had and had so many sneaky results where he muscled the car around with no pace.
Only a few morons will disagree with you on that Bris. Lost by 3 points in an inferior car, and lost 15-25 points in a single race being taken out into turn 1. A true champion and spoke very well in the podium interview
Thinking about it, he had a silly amount of pit errors and mechanical problems.
Also, top drive by Petrov. Heikki is a nice lad but Petrov has shown to be easily his measure and will be interesting to see what happens next year with Pic already signed and who the other driver will be.
So, bye bye Kobi...been fun :(
how many races lost while leading this year?
3? 4?
something like that. and then mugged here too :/
I don't know the exact figures, but all the incidents add up to a whole buttload of points
Hamilton lost plenty of points, but as Harry said, mechanical failures, while not being the drivers fault, are an issue with the car that the TEAM (driver being apart of that team) need to resolve. It's completely different to a frenchman wiping out half of the grid into the first turn.
You can taste the tears of the fanboys on forums all over the place. Talk about sore losers
The denial and anger would be sad, if it wasn't so funny
Ah well, I think vettel did a great job all year, and redbull deserve the plaudits for producing another great car
Looks like Roman is going to be scapegoated for quite some time to come, too bad pastor gets away with his shitty year without half the attention
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
