Hey guys,
I am looking for an r32 gtst or gts4, so far with not much luck. I want to buy something that has been well looked after and not something that has been thrashed around and poorly maintained by someone who doesnt know much about them. If you have something or know of someone who has an R32 of this description i will be interested. I have cash also. Thanks guys
https://www.sau.com.au/forums/topic/384313-wanted-r32/
Yeah you guys make good points. Its just so hard to find anything in tas! Not much about to choose from.
What do you guys think of this:
http://tas.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-cars-r32-turbo-skyline-W0QQAdIdZ333930970
I'd appreciate your opinions
https://www.sau.com.au/forums/topic/384313-wanted-r32/#findComment-6133378
if you want to do skids, its a no deal, as its AWD. they are heavier, but if you want grip go for it.. ask someone in the know on here if they know it, or will look at it with you
I think the gts4's can also be RWD if you remove the 4WD fuse. Same as GTR's. Im not that desperate to "do skids" however it will be a nice option since ive been driving a gay FWD for a while lol. More just after a street car that will be reliable that i can build up myself. Be good if someone on here knew/knew of the current owner.
https://www.sau.com.au/forums/topic/384313-wanted-r32/#findComment-6134110
Yeah you can hook up a switch which bypasses the fuse to put it back to RWD, but you're still carrying a decent chunk more weight for the AWD system. That being said, if you have a few fat friends you may not even notice ;)
I don't know the owner but someone on here would, generally people only interested in burnouts will avoid the AWD versions so maybe you'll get lucky with the engine? As I'm sure you've heard, if you're building from stock and you want something remotely decent it will cost you heaps (HEAPS) more than buying something already built.
I almost bought a gts4 about 4 years ago, but pulled out as a once over from brad at boost automotive turned up a lot of issues. If you're up north I'd suggest a good check over before purchase, and take notice of your gearbox when you take a test drive as it's under a bit more stress in AWD's.
Also, last piece of obvious and most likely misguided advice, drive skylines you don't want before buying one you do. Come to one of our meet ups or whatever and people will give you a lift I'm sure. Driving some POS skyline would have blown my socks off after a couple of years in a FWD hatch, so make sure it's the real thing, not just a comparison with another type of car :P
https://www.sau.com.au/forums/topic/384313-wanted-r32/#findComment-6134980
Thanks mate! Appreciate the advice. I think i might leave that one and keep looking. I asked if i could take it for a professional inspection and he declined so thats not a good sign.
https://www.sau.com.au/forums/topic/384313-wanted-r32/#findComment-6135641
Yeah definitely get the inspection done, it will save u many, many $$$$ in the future. I got screwed over because i didnt do that when i bought my car due to the fact that the guy selling seemed like a genuine and honest person, big mistake on my part :spank: . Its almost all good now but i have had to spend a substantial amount more $$$ than i was hoping too and i havent even had the car that long. There are good cars out there just take the time to find one and u wont regret it, u will never go back to FWD :P Good luck.
https://www.sau.com.au/forums/topic/384313-wanted-r32/#findComment-6144649
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
