So this afternoon I will finally be picking up my 2002 250t RS four v hicas after importing it myself to NZ. I am starting this thread as I will no doubt have lots of Qs of the coming weeks.
The first of these is what do the side curtain airbags look like? I have noticed these small sorta rectangluar bits at the top of each pillar in between the front and back doors, is this the airbags or does everyone have them? Will try and post a pic if I can.
Also if anyone has any Qs about importing your own motor to Nz then I'd be happy to help
https://www.sau.com.au/forums/topic/384887-new-m35-owner/
If they are airbags shouldn't they have "SRS" inscribed on them?
AFAIK it was a factory option and not many cars came with them...
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6139366
Lol I'm sure mine will b fine unless the mrs is driving it, having said that I did write her car off rather spectacularly a few years back, airbags taste quite stingy from what I remember! Other driver ended up in cuffs though so it was definitely not my fault.
I've just been to see my Stag, not getting it until tomorrow now as it failed compliance. Only needs one headlight level adjusting though so it's all good. The place phoned me and opened with" its gonna need some repairs", my wallet winced til he told me what it was lol,
First time I ever sat in one was today, impressed so far and really pleased as I've saved a fortune importing myself.
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6139716
OK thanks for your help so far guys, the compliance place fixed whatever was up with the headlight for 30 bucks so its all good. Today I actually got to drive the car instead of looking at pictures everyday like she's some dirty girl off the internets :wub:.
First impressions; so smooth, so very smooth and quiet. But then it turns into a beast once the turbo winds up, the grip is just at silly levels. It feels a bit floaty on occasion but I guess that's coz I'm used to driving on hard suspension set-ups?
My Turbo is quieter than I expected, you can hear it but its definitely not loud like I've read many others report but I guess this is a good thing? It does come with full Nissan service history so I'm hoping I'll get some more life out of it yet.
One question, the button that locks all the doors located by the drivers elec window controls does not lock the drivers door is this normal?
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6141589
$30 - can't have been much of a problem :thumbsup: .
I thought grip was great on mine too. Then I started modifying & it gets heaps better.
You may get years more out of your turbo if you look after it with quality oil & reasonable change intervals. Or you may not.... hard to tell really.
Yes, the door lock is functioning correctly.
Can you post some pics? It's always nice to check out the new guys ride. And welcome to the Stagea forums. We are generally a decent bunch around here.
Edited by Commsman
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6141638
Well I did my first service today, used some Castrol Edge 0w40 and a Ryco oil filter. Also put a new air filter in there. That tray on the bottom on the engine is a bore to get off but once that's done the sump and filter are easy to access which is good. Air filter took me bloody ages to figure out that you just need to give the airbox a good yank and it comes right out haha. Also had a good poke under the car, no nasty surprises so I'm pleased.
I def do NOT have the side airbags.
Quick n00b question about tyre pressures, should the back be higher presure than the front or the other way around? Have the sticker telling me the pressues but its in jap of course
Have given her a bit of a :spank:and have to say LSD = win; lots of fun. They don't half shift for a big car.
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147331
40psi all round :)
I used to run 40, thinking it was on the high end, then more than one tire place told me that was too low. They suggest closer to 50psi as I'll scrub the edges off anyway so might as well wear the middle of the tread with the higher pressure. Ask around as I'm keen to know if it's just a local thing or if it's a widely held belief. BTW, may not be as applicable for different sized tires. Mine are the popular M35 size, 245/50/18.
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147457
Huh????why?
"please explain"
Best combination between comfort, economy, tyre wear rate and handling.
Any lower and it felt soggy and I found a noticeable decrease in economy.
You go lower or higher?
Reasoning?
EDIT: I should mention that was with 225/55/17's although I did run the same pressure when I had the Nismo's (234/40/18).
Edited by iamhe77
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147482
Reasoning?
I run in between 34 and 36 on the street for extra grip unless I want to have some fun in the wet!.....Aussie roads are shit so 40PSI would no be a nice ride and imo you get no handling improvement. I always look at tyre pressures as another suspension adjustment.
running 55 series tyre though I can sort of see why you went up in pressures depending on your tyres. E.G. Nankangs felt mushy on the sidewall even at 40+ psi on the track...the Falkens I have only ever gone to 38-40 PSI on the track with bleed off!
https://www.sau.com.au/forums/topic/384887-new-m35-owner/#findComment-6147611
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
