post-87903-0-16591800-1323075306_thumb.jpgpost-87903-0-88104400-1323075295_thumb.jpgpost-87903-0-60164000-1323075278_thumb.jpgpost-87903-0-52727800-1323075287_thumb.jpgpost-87903-0-60164000-1323075278_thumb.jpgHi There all,
New to posting but have been here reading avidly since Sept.
Have bought myself a R33 Series 1, and loving it to bits!!
it was stock, and have since put in a Just Jap 3inch cat back exhaust, running beautiful, no problems.
Then about 3 weeks ago decided to install a Just Jap FMIC Kit.
I read loads of guides, then got all the original piping out etc, all no problems. This is when the issues started.
Have installed all the piping, using all but 1 of the stock silicon joiners supplied (on the hot side of the intercooler 3" to 2.5" reducer).
Idle is FINE, however as soon as it gets to boost, it just chokes, like its cutting out...
I thought this was a boost leak at first, but have removed ALL the piping twice, and checked with soapy water for any boost leaks, NOTHING. all clamps are exceptionally tight, and rock solid from what i and 2 friends can tell (fairly experienced with this kind of thing).
Have a look at the video, and you will see the issues im having.
i havent touched anything else, just this intake work, and this is the head ache i have no.
Was hoping that someone would have had this issue / can help diagnose, cause im running out of ideas.
here is a list of things i have done.
  • Changed all intake piping.
  • custom built a mount for the front pipe so that i didn't need to trim the fan blade and also help the front pipe sit flush
  • checked all pipes, tightened all clamps
  • Disconnected the battery for a number of days (to reset ECU??)
  • checked connection to AFM (just wiggled and sh!t but all looks ok)
  • have tried pulling the vacuum feed i have used for the actuator doesn't make any difference - (have heard that should use a line on the intake, and i will, once i have diagnosed this problem, im not convinced it is causing any issues)
Thats about it, please let me know if you have any suggestions ideas.
Have also included a few photos to perhaps help...?
Matt
Has the piping between the AFM and turbo been changed? Possible AFM reversion if so.
Try unplugging the AFM to see if it does the same (will go into limp home mode and be rev limited to 2500).
Are you sure a rag or something wasn't left in the piping or the intercooler?
Sounds like a massive leak to me the way its running, thats how it runs when youve blown a pipe out. If you want to do a proper leak test get a pcv end pipe and cut a hole and glue a compressor fitting onto it then take the afm off and stick that on and run compressed air through 15psi or whatever you want and listen for leaks, cant think of any other reason it would run like that since all youve done is put a cooler so all I can see it being is a leak somewhere or some hoses you forgot to plug in.
Thanks for the comment.
Certainly no rags in the piping. been really careful everytime i take it out.
I havent touched any piping from the AFM back, just the intercooler piping.
one of those photos shows the AFM and the first part of the piping, looks stock to me.
funnily enough it might even be something to do with the AFM, its doesnt like going much about 2500..
would it be making those sounds now if it was in limp home mode?
from memory i have disconnected the airflow meter and it doesnt too anything to help or change the symptoms in the vid.
You're not going to be able to build any positive pressure at all in neutral anyway. If it's being rev limited @ 2500rpm then in all likelyhood the car is in limp home mode and I would be getting the error code from ECU, will confirm if it's the AFM or not, and if It is the AFM it could be something as simple as the solder joints in the AFM need to be resoldered.
Unless you man handled your AFM, it should be fine. They are fragile, yes, but cmon people run 20psi through these things with big turbos... That is alot of suction. Some people put them in the cooler pipe, that is alot of pressure on the components. Surely dropping it, disconnecting it or what not won't kill it. None the less it is a component which you need to confirm it either works or doesn't.
I thought most, if not all, skylines have the limp home mode if the AFM is f**ked.
How did you hook up the wastegate actuator? To control boost...
Hi, ive teed it off the BOV for now.
know its not good practice, but im convinced that isnt what is causing these issues... surely that would just mean i would be over boosting, which isnt what is happening here?
By the sounds of it i might have problems with the AFM ? ill try running the codes from a thread i found..
http://www.skylinesaustralia.com/forums/topic/266512-reading-nissan-fault-codes-ecu-fault-codes-how-read-them/
reckon thats the best way forward? before jumping at buying a new AFM?
Cheers all for your help appreciate it.
Matt
Possible curse on his car by a magic gypsy also?
Please think before you type. He didn't say it was splutering/dying after changing gear or lifting off but just on boost.
that sounds exactly like when the AFM is not connected or a faulty AFM, could be bad luck and you might have bumped the AFM and it died, best to go borrow one from the forum members
Are you sure the series 1 ecu has limp home mode??
Yeah, i have an s1 and it goes into limp with the afm disconnected (forgot to reconnect once)
ok great. I'll check it tonight hopefully.
Our of interest does it jump straight out of that mode once It was plugged back in?
Or did you need to reset the ecu?
Cheers for the help all
So thought I would post a quick update
Ran the codes tonight and came up with AFM code
Then got my multi meter and checked the voltage on the plug.... nothing.
So restripped and housed the plug.?? Perfect.
It must have broken or come loose when I took the airbox out..
Thanks so much for all your help guys.. was awesome to narrow the issue down
Thanks again
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
