hahah Like I said, best I can manage with a welder is making holes in stuff that shouldn't have holes in it. But yes good cages seem to be a bit of a black art, which is why I will only ever get one from guys who have been doing/perfecting it for years
Good question. Part of the learning experience. We hadnt thought of the harness bar because i hadnt planned on running a harness yet. Ill upload more pics i just took later.
The rear legs are directly behind each seat in the middle so it may be possible to weld a harness tab and run two straps from a single point. ?
Or we can weld the harness bar between the main hoop
Yeh, harness bar in the main hoop is probably best anyway. Some argue that longer harness means in a big accident the longer belts stretch a little (we are talking mms not inches) and this flexibility reduces internal organ damage due to high Gs. Of course being shorter if the car distorts your belts are less likely to loosen as things move....but main reason I like harness bar between struts rather than the main hoop is acces and putting rims etc in the back seat even though you have a cage
any plans for cages to suit different cars?
i have a s13 and am looking for a cams approved bolt in half cage with a diagonal cross bar between the rear legs and a harness bar across the main hoop.
only thing is im located in tasmania so i couldnt offer my car even as a demo
Roy- didnt you remove a brown Davis cage for a Pro Fabrication cage?!??
Yep, The Brown Davis cage was similar to what I have now...but I couldnt recline seats all the way back as my Momo seat is quite wide and used to hit it. Also didnt have a diagonal in the main hoop which i was worried would limit access for rims and tools. Pro Fabrications did a top job to package the bolt in cage far tighter to the body, provide a diagonal in the main hoop all whilst giving me the same, if not more rear access for storage of stuff when getting to/from the track
Closed.
If businesses wish to trade, sell, promote here on SAU - You are required to become a paying trader just like everyone else.
Info can be found here:
http://www.skylinesaustralia.com/forums/topic/294953-are-you-a-business-want-to-advertise-on-sau-click-here/
To everyone else that will no doubt read this... Read on.
Starting in 2012 the Fabrication section will be clamped down on. You guys know who you are that are getting some good business from posting a "what I've been up to" thread.
This is your prior chance do the right thing and become traders as an act of good faith, or run the risk of not being able to post here at all.
Fair is fair and SAU doesn't run for free.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
