  • Replies 52
those vibram five finger shoes are pretty light, definately wasnt them was it?
Some people are starting to wear them in my gym, dont know weather or not they will catch on. What is annoying me though is members taking their shoes off to squat/deadlift, not just at the power rack but even with a 20kilo bar in the free weights area. I know there may be some minor benefits but no need for it. .... sorry going off track, just needed to vent :-) might start a new thread on it.
I used to take my shoes off to squat/dead, now I just wear free runs.
I would've laughed in the face of anyone that told me to put them back on.
I dont see how it could possibly affect u so focus on your own workout and stop worrying about what everyone else is doing
Your supposed to deadlift in no shoes mate.
Here are some approved deadlifting shoes
http://www.titansupport.com/products/deadlift-slippers-men-s.html
But some people wear converse all stars.
Basicaly you want flat hard surface under your foot
i understand there may be some benefits associated with no shoes, however, i dont feel it necessary in your everyday fitness first gym etc. people have been deadlifting with shoes on for years! if its good enough for ronnie then its good enough for you:
http://www.youtube.com/results?search_query=ronnie+coleman+deadlift+800+lbs&oq=ronnie+coleman+dea&aq=1&aqi=g8&aql=&gs_nf=1&gs_l=youtube.1.1.0l8.735.4549.0.7072.18.18.0.5.5.0.387.1780.7j2j3j1.13.0.
*hope that link works* just incase it dont, its ronnie doin his 800 pound deadlift...... IN SHOES! *GASP HORROR*
gtst - you are correct a lot of em wearing the converse all stars and a blank no name brand as well.
dezz, put it this way, freeweights area, flat bench, dumbell press, 130 kilo overweight patrons walking around with no shoes on with toe jam..... sorry but there has to be some level of hygiene, or are you one of those customers that i have to address not placing a towel on equipment :-)
Do you know how expensive it is to get the equipment reupholstered, not cheap! plus the down time of the equipment can also make it annoying for patrons as well.
Ronnie frequently trains in WORK BOOTS.
Have a look at the video again.
those boots are not jogger/sneakers.
anyway, I get your point.
If training at a fatness first you need a towel and shoes and latest micro fibre training gear and flouro shoes which cost hundreds of dollars and leather weight lifting gloves while doing DB flyes using 8kg bright coloured rubber coated DBs while listening to One Directions latest hit blasting across the gym, in between trying to get a glimps of your tanned self in the hundreds of mirrors and pretending that you're not.
For those still interested in online shops after all the ranting etc.
http://runningwarehouse.com/ and
http://www.wiggle.co.uk/
are my favourites by far. 2 pairs delivered for cheaper than 1 at the local.
And yes I am aware of the offshore stores taking local money etc etc, but I can't justify the cost of runners in town when I don't make a huge deal of money myself. Spending half a paycheck on a pair of shoes I'll wear out in a couple hundred km's is f**ked.
I used to wear cheap flat sole sneakers (Vans) which work for squats/deads as the soles are flat and thin. Cheap $5 Chinese shoes / kung fu shoes would be really good for people other than me (my feet are too big)
I'm not sure if anyone does plyometrics but, if you have a crack definately go some strength shoes/ jump soles for plyometrics or a cross trainer that has bulk cushioning for the ball of the foot/toe area.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
