Thanks for the good comments, Glad your happy with it James and if you need any other work done just let me know
Any chance you could post pics of the gauge pod once it's in?
Also do you mind if i use these pics?
Cheers,
Pete
  • Replies 50
I'm in for one. Will send through a deposit on Friday (payday :)).
I'd also bee keen on one for the other side. Actually, if you're after ideas, I'd be mega keen on one per side with a sub enclosure in the left and an enclosure for 6x9s in both. Now that would be absolutely awesome.
What do you reckon the likelihood of that would be?
hey just to let you know i will be up/down for a sub enclosure as well if i still can, just waiting on money from dad as it's my xmas pressie but he doesn't like internet banking so he's waiting till he can transfer it to me the old fashioned way, will pm you when i get it for ur bank details etc
Pm sent
I'll be starting another GB within the next day as i have had a bit of interest so far
I Also have a few new items
1. Pillar mount gauge pod
2. Clock Replacement dual gauge pod
3. Still working on this i"ll post some info once it's sorted
And the count for the drivers side enclosure is at 4 once it's at 5 I'll take deposits and build a mold
Cheers,
Pete
Just go the subbox today, fitted it and it's frick sweet next thing is to fit the gauge pod
thinking about getting the r/h one but need it for an amp.
Cheers
Just put this in my car,only put a base model sub in for now but love the sub enclosure!! Excellent work, will defiantly recommend anyone with a stag to get one!
P.s, pardon the gear box oil stain on the carpet. :(
Ok Time for a new thread
Here's the link
Fgjoh Custom Fiberglass Sub Enclosure And Gauge Pods
Please post in the new thread and let this one fall back
Thanks,
Pete
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
