Depends on the car and what I'm doing with it.
Not long ago I did a strip and refit in a DB9rs.
Cost the owner a fortune
trents R33 GTR I did the while car build and included the interior.
At the moment have cars from dash sport & insight which are totally stripped bare
General rule if all I'm doing is a cage then no stripping is included. If I'm building a whole car then I work it into the cost.
I have a no shit box policy now days. (seriously)
I've had to become very picky with the cages that I take on.
As of lock up time tonight there is 7 high end cars waiting in line for rather large cages.
And an additional 5 cars waiting for a phone call to bring them in.
That basically puts cage work at a 2month wait time.
I do suspension setups yes depending what the intended purpose is.
As for undercar bracing I dont really do anything regularly with it as the majority of the car I see through the place are getting or have cages.
I can design and fabricate undercar bracing if you are willing to factor in design time as well as actual fabrication time.
Best to get in contact when your ready and see if my shedule fits around yours.
Im currently doing a comprehensive cage for Dash sport
Its an EVO IX RS
I was contemplating doing a write up on the next cage similar to the one I did years ago about cage fabrication. It seems every forum but this one has a thread dedicated to roll cages.
will do champ............im doing a big build and bracing i will spend $$$$ on no issuse...........cause pretty much its a land barge
Its an EVO IX RS
Brad can you get back to me? Still waiting on a reply..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
